| diyAudio Sponsor | ||
I was fortunate to be gifted a pair of globe 50s last christmas.
Now I want to make a simple 50 amp using these tubes, and am aware of the 10K grid resistor issue. What if I use a 417A with plate choke, cap coupled to the 50 with grid choke? Will the 417A have enough grunt to drive the 50? If this will work, how do you compute for the driver parameters when using a plate choke? I'm no designer so pardon my ignorance. But I can use TubeCAD |
#2 | |||
Previously: Kuei Yang Wang
Konnichiwa,
If you have a 50 operated at 400V/55mA with -70V Bias (read 1K2 Cathode Resistor) and a 3K5 load you should get 3.5 to 4 watt at clipping and you need a +B of 470V plus Output Transformer losses. If you take this +B you should use a slow warmup rectifier if you derive the Anode supply for the 417A from that HT line without regulation. If you do, use a pair of "dropper" resistors, giving you RCRC decoupling for the driver stage. This tends to sound better than just RC decoupling. The kind of anode load chokes I used had around 1K DCR and thus would drop around 12V DC in operation. So, in self bias mode for the 417A we would have a supply to the top of the anode choke of 2.5V (Bias) + 170V (A-K Voltage) +12V or 184.5V. For ease of calculation we use 185V. If our +B is 475V under normal load we need to drop 290V at 12mA DC current. This suggests 24K for the total resistor in the supply line, using a pair of 12K resistors and 10uF MKP Capacitors should give a nicely filtered 185V for the 417A. Other options are to derive the Driver +B via Zenner Diodes, Gas Stabilisers, an OB3 and OC2 in series will give around 195V regulated for the 417A driver stage. Or you could use fancy shunt regulators, solid state or hybrid. You could even build a seperate supply of 185V for the Driver Stage, say rectified with EZ80 and LCLC Filtered. It all depends how far you want to go. To me a pair of Monoblocks using seperate supplies might be interesting. Of course, if you have seperate supplies you might as well go for direct coupling between driver and power stage and in effect roll the gridhoke and anode load choke into one. Another note, if you make the heater Supply switchable you could also use 300B's and if you have an Output Transformer with enough primary inductance to allow mistmatching to twice it's nominal 3K5 primary impedance you could select between 300B, 50, VT-52 and VT-25/10Y... Sayonara |
#3 | |||
EDIT: Whoops, I see Thorsten posted while I was writing... damn my slow typing
#4 |
POST SCRIPTVM
Drop me a line and I zip you up a collection of articles/schematics for the 50 from my files (sorry folks, offer only for Arnold). Sayonara |
#5 |
Here is an amplifier I built ( three units ) using three paralleled 6C33 and delivering 50 watts per channel, in Single ended topology.
I attach the upper view and will follow with the view inside. The power supply is in a separate box and connected with a simple twin wire cable. The filament and driver transformers are on the main unit (the one shown). THD at full output is 6.5 % - Range 35Hz to 35 kHz at -3dB . You can find schematics and full description on AudioXpress magazine, July 2004. Uses quite expensive OPTs . Cheers,
Ari |
#6 |
Here is the inside view of the King III.
Bye
Ari |
#7 |
Arnold,
I forgot to add that, since the article was published on AudioXpress, some changes have taken place ( not significant but to further simplify this simple amp. Ari
Ari |
#8 |
Ari, I think Arnold was wanting to build something with Type 50 triodes, not a 50W amplifier... |
#9 |
Very sorry,
I must read the threads more carefully. Thanks for the comment. Personally I never had the chance of using the 50, but I know it has a wonderful reputation. By the way, is there a means to classify the valves by reputation ? Of course this is not necessarily strictly correlated with quality. Surely those who have a wide experience have some words to say. It's probably a bad idea. Forget it. Thanks again. Ari.
Ari |
#10 |
Bonjour Ari,
Your humility is very impressive; I have watched your designs for a long time, Ari, and they are very, very creative, indicating to me at least a fundamental understanding of music........ I was always very impressed with your phase splitter using an EL84 from so long ago - lateral thinking! And your 6C33C amplifier is impressive; your clever way of using a bipolar power supply is highly unusual. I have a couple, and would like to do something with them. For these low mu tubes do you think there is any advantage in driving the OPT in the cathode circuit rather than the plate? It would surely give a much lower turns ratio, and improve the damping factor? Cheers, Hugh |
| How to make a simple amplifier? | mehtadhaval | Everything Else | 1 | 16th February 2008 02:23 PM |
| How would you make this simple PCB or What? | KP11520 | Chip Amps | 11 | 2nd August 2007 01:47 PM |
| ok, i'll try and make it simple. | PhoenixFL | Tubes / Valves | 9 | 13th May 2004 10:04 PM |
| I want to make a simple UL PP amp | arnoldc | Tubes / Valves | 19 | 6th March 2004 01:32 AM |
| Page generated in 0.12543 seconds (82.38% PHP - 17.62% MySQL) with 11 queries |
