Single Ended Ultra linear, anyone built one? - Page 3 - diyAudio
Old 28th September 2008, 11:33 AM   #21
Elias is offline Elias  Finland
Elias's Avatar
Hello,
"Single Ended Ultra linear, anyone built one?"
Yes, coming on the way:
http://www.diyaudio.com/forums/showt...17#post1620017
It has a switch for UL mode.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 29th September 2008, 07:57 AM   #22
wrenchone's Avatar
Here is a picture of the "Shrine" amp in its current incarnation. When I retrofit the amp with the GSXE transformers, I'm changing the wires and pilot lamp from blue to yellow, adding oak angles to conceal the edges of the top and bottom plates, and substituting black oxide hardware for the zinc plated stuff to make it invisible against the black crackle case. All the guts are in the 6" cubical case.
Old 29th September 2008, 07:59 AM   #23
wrenchone's Avatar
Here is the current circuit for the "Shrine" amp,
Old 30th September 2008, 12:24 AM   #24
dtut is offline dtut  United States
Try this link.
http://db.AudioAsylum.com/cgi/m.mpl?...ut&r=&session=
Doug Tuthill
Old 30th September 2008, 02:14 AM   #25
otto88's Avatar
Do any of these dozen odd SE ULs output at least 40 watts?
or would that require parallel SE UL and more $ transformers?
Old 30th September 2008, 04:32 AM   #26
wrenchone's Avatar
Doug - I hope you bring your amp to BA this year. One - AR2 wants to hear it again. Two - I'd like to compare my little guy to your big guy using some nice, efficienct speakers. This would be to get some listening data points on the Edcor iron vs. the James iron, and the hybrid vs. the straight tube approach. I have a feeling that your amp will shine with high volume, bass-heavy material, but the difference between the two amps may be less discernable at lower volume levels. I'll never know unless I listen to another amp in comparison.
I'm working on another, larger amp using the "Super" 6BG6s and Transcendar output transformers (the large 3k units), but I seriouly doubt it will be ready in time for Burning Amp. It would be triode-strapped anyway, since the Transcendar transformers I have on hand have no UL tap.
Old 30th September 2008, 04:39 PM   #27
Yes, I'll be at Burning Amp again this year. Really enjoyed myself in '07. Great gathering. I'm working on finishing up a 12B4 SE that I want to bring and I'll bring the 6550, too.
Doug Tuthill
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 09:12 AM
EL 34 30W ultra linear GAK Tubes / Valves 70 24th November 2004 12:57 PM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright 1999-2017 diyAudio
