Amp intermittently blowing fuse at power up
Old 10th January 2005, 12:54 AM   #11
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
It should go after the mains fuse for safety reasons.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 10th January 2005, 01:21 AM   #12
el capitan83 is offline el capitan83
what is the best way to determine the correct size necessary?
for example, if the mains fuse is 3a slowblo, would a 16ohm(0 load) 4amp be ok?
or should i go higher in the amperage?
or is the 0 load resistance more the determining factor?
Amp intermittently blowing fuse at power upHide this!Advertise here!
AB Amp keep blowing fuse karlranks Solid State 3 29th May 2009 02:19 AM
Peavey 400 blowing fuse on power up Barnacle Instruments and Amps 11 2nd February 2009 11:49 AM
fosgate 1998 series power 500.2 amp blowing fuse jbrooksgametech Car Audio 13 26th November 2008 07:21 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
Fuse keeps blowing Vivek Everything Else 4 1st August 2003 07:31 AM
Copyright ©1999-2017 diyAudio
