DHT DC heater question
Old 31st December 2004, 07:57 PM   #1
etalon90 is offline etalon90  Canada
etalon90's Avatar
Default DHT DC heater question
Hi guy
I have a small question about DC heating.
I usualy use AC heater but since I use DHT in driver/input stage, I have to deal with dc supply...
According to RCA manual, with DC supply, the Rcathode should be connected to the negative cathode.
but do nayoen have try theses 3 variation.
Wich one could be the better?
(picture is not 100% clear, positive heater is pin 4, negative is pin 5)
Old 31st December 2004, 08:44 PM   #2
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
i would prefer the left solution but replace the resistors with a potentiometer with a value at, let say, 5 kohm, with the wiper connected to ground, put it in centerposition and eventually adjust it for lowest hum.
the above written applies to AC-fed filaments
if you use DC-heater there's no such problems with AC-hum.. and the negative on the DC-supply would anyway go to the powerground.
happy new year folks!!
www.joddla.net/audio/
Old 1st January 2005, 12:32 AM   #3
AndyN is offline AndyN  United States
Of the three you've suggested, I'd pick the leftmost.
Have a look at Steve Bench's pages for a more complicated / optimized version:
http://members.aol.com/sbench/humbal.html
The oboe, it is clearly understood, is an ill wind that no one blows good.
Old 1st January 2005, 01:44 PM   #4
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
The left consumes filament current in the divider resistors (about 1W total); otherwise it is electrically identical to the middle. The middle's problem is it uses two bias resistors (though one less than using two small dividers and one bias R), inconvienient at a glance or if you need to rebias it. The right is proper and the bias voltages will be correct (assuming you got the filament polarity as indicated in the datasheet).
This is a common misconception with DHTs: people assume that a divider is appropriate, especially with AC; it is. But not a single data sheet I've seen states AC filament power -- ALWAYS DC, with a certain pin grounded. NEVER center-tapped for DC.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 1st January 2005, 01:55 PM   #5
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
I allways use the righthand connection,
with regulated DC.
cheers
- Jan -
Old 1st January 2005, 09:34 PM   #6
etalon90's Avatar
I`ll go with you guy (and recpect the RCA datasheet too)
I`ll use right connection (I used left with ac in past but wasn`t sure if it where good for DC)
Martin
DHT DC heater questionHide this!Advertise here!
Simple heater question athos56 Tubes / Valves 4 27th May 2009 05:31 PM
5 VDC heater question sgerus Tubes / Valves 4 21st June 2007 04:48 PM
5687 filament heater question dr._sleep Tubes / Valves 2 25th August 2005 03:45 AM
Heater Question lpd Tubes / Valves 4 20th February 2005 05:35 PM
Heater winding load question. G Tubes / Valves 3 22nd May 2004 06:40 PM
