| diyAudio Sponsor | ||
#11 |
You should be fairly safe against almost any fault involving DC on the outputs as long as the output coupling cap doesn't go leaky though. The key word here is fairly safe. Why chance being fairly safe? Add $1 worth of 3.3v zenier diodes and protect your investment. Two zeniers on each channel will NOT change the sound and WILL protect your sand amp. Note*** The last line stage I built(1 month ago) had 600v $30 ea coupling caps but still managed to do $50 in parts(damage) to my SAE amp. I repaired the SAE and added the zeniers to the input jacks......no more worries. |
#12 | |
Did you ever figure out what caused the fault? The zeners will protect the input of the amp, but the preamp shouldn't be out to destroy the inputs anyway. Maybe a little bit of valve-sand rivalry I probably wouldn't have posted that if I ever had an input stage destroyed. |
#13 |
Dont' forget to load the input with low value resistor to avoid parasitic feedback that can be created with the addition of the Zener Diodes on the input. Say 220 to 250 ohms.
Regards Anthony
I like to stay current! |
#14 |
When a tube preamp is turned on or off the output will swing through a large range. If the coupling cap is a high enough value, the charge / discharge curent can damage the input transistors. Really bad if the amplifier power is on.
Zeners may affect the sound and you have to suze them for peaks in the music. 1N4148 in series with the zeners may help in that respect. The best solution is a relay that shorts as soon as power is removed in the preamp and stays shorted for a while after power on. This will not affect the sound as much as diodes. -Chris |
#15 |
How would the zener diodes be connected? Sounds interesting. I had a bad experience with a tube pre-amp connected to a SS amp and would like to avoid a potential problem in the future.
#16 |
Nelson Pass used a Zener network in his SOBOZ design. If you go to passdiy.com you can download the article. He describes in some detail how the circuit works, just be sure to follow his advise about the 220R resistor on the input.
Regards Anthony
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.09291 seconds (77.78% PHP - 22.22% MySQL) with 10 queries |
