diyAudio Sponsor
Old 19th January 2006, 01:45 AM   #21
When I got my first HF-12 about a year ago, my Power tranny vibrated like crazy and it had a loud hum. After about a month of part time usage it stopped completely. I would guess the can cap has to reform and did since both problems went away. You should be fine going up on the values of the can cap and many reccomend this. Keep the under chassis cap located under the chassis ( the first one after the rectifier at 40 or 50uf max though since these amps have a small rectifier tube. I increased the coupling caps and it sounded much worse so I wen't back to .1uf orange drops and it's great now. I increased the 50uf 25v cap at the output tubes to 100uf 150 volt and it sounds more open and the instruments playing are more distinct. I doubt that more than 100uf would be any better.
Steve
steve
Old 19th January 2006, 11:27 AM   #22
By the way, so you have the old 12au7 (tube in v2) or more common 12ax7 model??
Steve
steve
Old 19th January 2006, 03:18 PM   #23
Both don't have any 12AU7s. No, I don't have the early versions.
Ok I could try what you've done.
Antoine
http://dmsaudio.ca/
help w/ Eico hf-81 paulnparis Tubes / Valves 3 29th August 2009 12:57 PM
FS Eico HF-85 tube pre-amp jdeitch11 Swap Meet 0 19th October 2008 12:27 AM
Eico HF-32 crick Parts 3 25th June 2007 01:18 AM
12a?7 in Eico HF-12 ivegotmono Tubes / Valves 7 24th March 2006 03:52 PM
WTB: Eico HF-81 mrdon Swap Meet 0 20th October 2005 02:02 AM
Page generated in 0.06496 seconds (77.95% PHP - 22.05% MySQL) with 11 queries
