diyAudio Sponsor
Old 30th December 2004, 07:31 AM   #1
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Tube PWM driver
Yeah, so I got bored. Here's a five tube PWM generator circuit!
Depending on the output level, it should be basically ready to slap onto an SE output stage, actually. Just add a plate filter choke so the switching noise has somewhere to go.
I have no idea if the hysteresis resistors are enough, if I ever breadboard this I guess I'll find out.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Need Help for Tube Driver variable Car Audio 7 7th June 2007 07:49 AM
Look for a beefy driver tube. Shoog Tubes / Valves 20 27th April 2007 07:00 PM
Driver tube for 45 interstage 1:1 barossi Tubes / Valves 1 11th January 2005 04:32 PM
FA: Tube Line Driver LDX-23 and LD.2 justice29 Car Audio 0 7th February 2004 04:41 AM
input/driver tube brsanko Tubes / Valves 0 13th January 2004 08:18 AM
Page generated in 0.06370 seconds (69.86% PHP - 30.14% MySQL) with 11 queries
