diyAudio Sponsor
Old 1st January 2005, 11:01 PM   #21
audiousername's Avatar
Default Re: SRPP
Originally posted by Mr. Triatic
btw, what does SRPP stand for? -i know that PP stands for push-Pull, but the SR?
Originally posted by Yugo
Shunt Regulated Push Pull
Yes. But it also goes under many other names. There is also argument whether it shunts, regulates or is even push-pull. But that is an argument for another day.
In fact the original name for it was the Series-Balanced amplifier (on its patent in 1943 - US Patent no. 2,310,342)
Old 2nd January 2005, 05:03 PM   #22
Mr. Triatic's Avatar
hehe, it's clearly a fact that audiousername have done his homework! 8-)
thanks for info, i've searched the net, but i came up with nothing...
the amp has been running for two days now, it works flawlessly, sounds nice indeed..
i have adjusten the platevoltage to 145V instead but the difference in sound is neglible.
www.joddla.net/audio/
Old 5th January 2005, 10:09 AM   #23
too bad that the forum have been inaccessible for a few days now, but now it's up and running so i will update on the progress with my preamp, still works fine, i conducted som measurements today and the results are good, 25-24000Hz -0dB, no significant overshoot when i feed it with squarewave, clips softly when i overdrive the input, output swings max 5V when driven fully.
i screened the transformers and made som aesthetic changes:
Old 5th January 2005, 10:14 AM   #24
more..
Old 9th January 2005, 11:50 AM   #25
ok guys, here's the schematic, comments please!
PCF801 - pentode section has remote or sharp cut-off? ilimzn Tubes / Valves 3 31st January 2006 07:39 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Anyone try sharp cutoff pentodes in a p-p output stage? aletheian Tubes / Valves 3 28th November 2005 06:28 AM
Cutoff theory Grandma´s_SUB Parts 0 6th November 2004 08:25 PM
Page generated in 0.08003 seconds (72.99% PHP - 27.01% MySQL) with 11 queries
