| diyAudio Sponsor | ||
#41 | |||
Forums were down fir a couple of days, so I couldn't respond.
OK-- no more easy-questions-for-me-to-ask-but-hard-for-you-to answer questions. I built a Bottlhead Paramour / Foreplay kit for my first attempt at tubes. I was afraid of the high voltage and knew nothing about them, so I went with the kits to solve some problems I was having in the knowledge department. They're 2A3 SETs and while I like them, I think I would like to try a push pull. I am not asking for further guidance on push-pull topologies-- I know that this is markedly tougher stuff and I don't want to press my luck by asking more questions, so I will be heads down in books for this one (of course, if you want to...). I am, however, asking why some feel that PP sounds better than SET. Also, are there any design tools that are worth buying? The software on the Glass Audio website is pretty cheap and intriguing at that (TubeCAD, Push Pull Calculator, etc.). Also, also, I bought an old Pilot mono tube amp from a TV repair shop and I'm thinking I can use the iron. Is there anything I should check to make sure this is safe to use? Thanks again, Kofi |
#42 | ||||||||
![]() Quote:
![]() Quote:
Claudio Bonavolta has a webpage up with a basic rundown of the most common phase splitter topologies here. Actually, his is whole site worth a good look, especially the schematics of a few PP amps so you get a feel of how they are put together. Of course, since PP amps are more complex, there are a fair few ways of putting them together, as opposed to SE amps, where you don't really have all that much choice. Quote:
Also, PP amps may have a different distortion profile to that of an SE amp, and many have argued that PP is bad because it cancels the 'benign' second harmonic. But that is only the theoretical case, with perfect phase splitting, perfectly matched valves, and perfect summing in the transformer. Unfortunately we don't live in a perfect world. Below is the distortion characteristic of VSE's PP-1C amp (EL34 triode-strapped PP). The fundamental was 1KHz, so second harmonic is the peak at 2KHz, third is at 3KHz and so on... You can find out more about that amp and schematics here. I think I recall Allen Wright posting somewhere that it was taken at 1W output, but I'm not sure. ![]() Actually, I should have reccomended this before. Steve Bench's Of Loadlines, Power Output and Distortion series (you'll have to look for it on his site - it spans five pages) is an excellent introduction. And he explains things much better than I have - and there are formulas too. You really have to be able to understand a loadline to design something competently. Quote:
I don't have any designing software apart from PSUD, and LTSpice - which I don't know how to use. Both of them are available free.Quote:
On safety issues, I suppose one thing you should look out for is the state of the insulation of the windings. You really don't want your B+ appearing at the output terminals There are probably other things which I don't know about and maybe others could help you out there. I really don't have much experience recycling old stuff.Quote:
#43 | |
I've made my 300B amp based on the JeLabs and, since I don't have a 50 Ohm/2W hum pot, I have connected the cathode resistor from the centre tap of the 2,5-0-2,5 V ac transformer to ground. (as they show at the schematic from the "SE Amp CAD" software).
I still have a very low 50Hz hum, so I am wondering if it's really worth to buy the 50 Ohm/2W pot. ¿Do you know some supplier in Europe? Quote:
#44 | ||
![]() Using the CT of the filament transformer as the cathode connection has been done before, it's just that it doesn't allow fine adjustment. Oh, and the signal has to go through the windings of the filament transformer, which some may object to. Quote:
Jason |
#45 |
Thank you Jason. I will probably order the pot from Angela and don't let my signal pass through the supply transformer anymore. Too many turns may make it feel dizzy
BTW: is it normal to have a blue light at both sides of the 300B? It's beautiful, but I don't know if it means there's something wrong. Rebel electrons want to escape from the bulb? Cheers Manuel |
#46 | |
I don't know.... I actually have never worked with the 300B personally! As long as it isn't the soft purplish glow associated with a gassy valve I don't think it should be anything to worry about.
Jason |
| Is my 300B tube dead? | Evenharmonics | Tubes / Valves | 5 | 25th May 2009 04:51 PM |
| 3 terminal regulator with 3 terminal shunt reference | BWRX | Power Supplies | 10 | 12th April 2008 03:49 PM |
| My audionote Kit one have problem on 300B cathode terminal | ramnmic | Tubes / Valves | 4 | 13th January 2005 06:56 AM |
| Port tube and terminal question. | TonyW | Multi-Way | 10 | 13th March 2004 07:48 PM |
| Page generated in 0.13239 seconds (82.58% PHP - 17.42% MySQL) with 11 queries |
