| diyAudio Sponsor | ||
#81 |
Fyi, and fwiw, the particular model I worked on had quite adequate output transformers which did work nicely in fact.
The HF stability I didn't find to be a big problem, the DC bias shift is what killed the tubes... glooooowwww, phfttttt! If there was an HF stability problem on this model, I didn't catch it... heh. The B+ was less outrageous than that found on a certain California amplifier maker's gear (last letter in the name is "L"). And, at least this one didn't have the screens run into oblivion... I had to check with JC on that amp just to check my sanity because I couldn't believe what I was seeing (popping frying screens at full output level) to be sure that the B+ and screen voltages were not sane. They weren't. Anyhow, if the French amp's drive circuit was properly set up it actually would have been a nice amp... excellent chrome, not much gold on that model _-_-bear The ironic part of the "L" amp was that owner had to have me change it back to stock so he could sell it!
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#82 |
ha!
lookee here, if it ain't randy and jc talking guitar amps! every time you guys open your mouths i learn something word to the hardware hackers...thanks
-blackie. |
#83 | |
JC's got it totally covered! I'm just part of the cheering section! Word to the wise - Blackie is da man - makes some super fine tube gear and guitar amps... check out his site! _-_-bear
#84 | |
haha krazy!
-blackie. |
#85 |
Whoa! Look out!!
Are they shrink wrapping them on the newstands these days? Hmmm... don't expect the public library will have it... _-_-bear PS... JC, where's the rest of the Fender lowdown stuff...?
#86 | |
here's a link http://www.tubesville.com/playboy.htm
-blackie. |
| a better pentode for less! | smoking-amp | Tubes / Valves | 16 | 12th August 2008 01:58 AM |
| All pentode PP amp? | ray_moth | Tubes / Valves | 7 | 31st January 2007 12:52 AM |
| Anyone using an 813 in pentode? | Svetlana | Tubes / Valves | 7 | 30th August 2006 11:01 PM |
| A small no-fuss pentode/pentode SE amp | Tubes4e4 | Tubes / Valves | 13 | 1st January 2006 05:16 AM |
| Big pentode help! | massimo | Tubes / Valves | 0 | 13th February 2005 10:44 PM |
| Page generated in 0.12387 seconds (68.62% PHP - 31.38% MySQL) with 11 queries |
