Tube Cooling Recommendations
Old 21st December 2004, 08:52 AM   #21
Layberinthius is offline Layberinthius  Antarctica
Default Re: The problem children
Originally posted by gingertube
I've done as above as much as possible - the tubes are a liitle close together for my complete satisfaction BUT this was dictated by the PCB I used (Menno van der Venne BBB70100).
40mm holes around the EL34s which plug thru into a PCB.
No bases on the boxes as yet hence them sitting on the timber to allow air flow from underneath.
EL34s in triode mode giving about 40 watts Output Power.
Thanks,
Ian
Kudos to your amp! Why haven't I seen it in the gallery?
Originally posted by Brett
It was 42 for a few days (outside) at my place last summer, hence the fan, to move any stagnant air and to keep other elements like top plates cooler.
I have no a/c except opening the doors and hoping the breeze is onshore.
Shore breezes, ahhh how I miss them!
Make a reminder all of you, if you're going to actually use fans, get the biggest one you can design for, the bigger the better airflow for the lowest RPM..
I need to get back on a shoreline
Tube Cooling RecommendationsHide this!Advertise here!
Any recommendations for tube for vari-mu compressor? leadbelly Tubes / Valves 5 8th April 2009 09:23 PM
Input tube recommendations... SpreadSpectrum Tubes / Valves 9 15th January 2009 08:41 PM
PC Cooling Fans for Tube Amps Dominguez Tubes / Valves 4 19th August 2007 02:06 AM
How cool is tube deep cooling? igormak Tubes / Valves 42 20th June 2007 12:14 AM
