Line stage board off from overseas. problems - Page 2 - diyAudio
Old 19th December 2004, 04:08 PM   #11
Jan
The parts sheet calls for 6) 100mfd/450V caps. I have them below the board.
Old 19th December 2004, 04:13 PM   #12
Default ling stage board off from ovrseas.problems
I see the bypass caps on the schematics but not on the picture of the board. When bypass cap dry out or fail,you'll get hum
Old 19th December 2004, 04:16 PM   #13
jan.didden's Avatar
Originally posted by burnedfingers
Jan
OK, I see. I thought they were different ones, the board looked low on the sheet in the pic.
How loud is the hum? Where is your volume control, before the preamp? Did you try with the input shorted?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 19th December 2004, 04:18 PM   #14
Any comments on the feedback change I made?
Old 19th December 2004, 04:29 PM   #15
jan.didden's Avatar
Well, the 330pF with the 100k will roll your freq response off starting at 5 kHz or so. This will defenitely sound dull -
In fact, this may cause the ramping, what is the ramp frequency?
The 1pF is not unreasonable for ultrasonic roll off. Try the smallest cap you can find, like 5 pF.
Jan Didden
Old 19th December 2004, 04:39 PM   #16
So I must have had a high frequency osolaton with the 470K resistor in the feedback loop?
Am I more in line with the different feedback resistor value?
Can't I leave it off (1P cap in feedback loop)since the tube amp should cover the low frequency roll off?
Old 19th December 2004, 04:43 PM   #17
Volume control is before the preamp. Tried with input shorted and still hum. Well, it(hum) wasn't super loud but you could tell it was there.
Old 19th December 2004, 04:44 PM   #18
SY's Avatar
The 1 pF cap in the feedback loop is for high frequency stability. It's easiest to use a gimmick cap, which is just two one-inch lengths of wire twisted together. Heck, the feedback resistor probably already has a pF across it just in stray...
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th December 2004, 04:48 PM   #19
Sy
Would you suggest trying it without the cap? I have never seen a
gimmick cap so I'm not sure on making one.
What are your feelings on the resistor change I made? R102 470K to 27K?
Old 19th December 2004, 04:52 PM   #20
jan.didden's Avatar
If I may (sorry SY), why did you make the change, and why that value?
Jan Didden
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Please check my PS pcb board layout for problems???? marchewd Tubes / Valves 6 10th July 2008 05:47 PM
Turret terminal board for line stage construction? Burnedfingers Tubes / Valves 22 5th March 2006 11:52 PM
Voltage readings on Bal Line stage Main Board Zapped Pass Labs 6 25th July 2005 06:42 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Copyright 1999-2017 diyAudio
