6ar5??
6ar5??
Old 18th December 2004, 05:22 PM   #1
amt is offline amt  United States
Default 6ar5??
I just aquired another Akai RTR and assumed it had the same amp in it as the last one I got (really a Roberts). Rather than a 6BM8, this one uses 6AR5s. I cant find much on them as to their fidelity, and the trannie puts out 250V, which I think is too low for a 6BM8. The OPT look like the same 5K as on the others.
Is this a decent tube? They are both shot so should I just use a different tube that will use 250V and if so, which one (6L6 maybe) Both the power/output trannies are in mint shape.
thanks amt
Old 18th December 2004, 10:48 PM   #2
GeirW is offline GeirW  Norway
GeirW's Avatar
Gday.
Here is the RCA datasheet
for the 6AR5, not mutch though.
http://www.mif.pg.gda.pl/homepages/f...049/6/6AR5.pdf
Old 19th December 2004, 12:00 PM   #3
mcs is offline mcs  Denmark
250V is fine for a 6BM8 amp. Other possible tubes could be the EL84/6BQ5 or 6V6/6AQ5.
I don't know anything about the 6AR5.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 19th December 2004, 03:09 PM   #4
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
6AR5 is a 7 pin pentode, equivalent to octal 6K6. 6AQ5 is a much easier to find replacement, though its pinout is slightly different.
Old 23rd December 2004, 07:55 PM   #5
Thanks for the responses. I re-read the 6bm8 specs and see now that there is a range of voltage operation which also varies depending on the operation mode. Im still pretty green as far as tubes go so nothing seems to be obvious.
amt
6ar5??Hide this!Advertise here!
Resources saved on this page: MySQL 17.65%
