829B/3E29 datasheet triodemode - diyAudio
Old 18th December 2004, 08:53 AM   #1
Question 829B/3E29 datasheet triodemode
Hello!
Is there enyone out there who has access to datasheets/loadlines for 3E29 or 829B in triodemode?
reg permagne
Old 18th December 2004, 05:52 PM   #2
Wink 829B triode data.
Hello,
I can mail them to you if jou want , got them from Peter Millett.
It a xls. file.
Martin.
Old 19th December 2004, 06:29 AM   #3
audiousername's Avatar
I also have the excel spreadsheet of the curves. I believe they were first prepared by Paul Raymond Leclercq (7N7 on this forum) - credit given where credit's due .
The curves were made with both sections tied together. Linearity is reasonable.
Old 19th December 2004, 12:01 PM   #4
Default 829B/3E29 datasheets triodemode
Thanks for the reply. This saves the Xmas. Now I can confirm that my workingpoint is where it should be. I run the tube in PSE-mode so the datasheets should be the rigtht ones. G2 max for these tubes are 240V and I have B+ at 320V. Is there some of you who has tried anodevoltage up to 600 in triodemode without breakdown (due to G2max)?
I am looking forward to receiving the spreadsheet.
Thank you very much.
Best regards permagne
829B Based Amp silverchris Tubes / Valves 15 28th July 2013 12:50 AM
829B SE Comments???? coldcathode Tubes / Valves 51 12th February 2010 04:08 PM
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
829B, 3E29, QQV03-20 Connector poynton Tubes / Valves 2 28th August 2007 09:28 AM
Copyright 1999-2017 diyAudio
