diyAudio Sponsor
Old 17th December 2004, 12:59 PM   #1
Question electrolytic can capacitor
Ok,
Thanks for the replies on the coupling caps, by the way.
I am replacing all of the electrolytics in the PSU. One of these cap cans is NOT wrapped in the PVC jacket, and since the case is grounded, if it were to contact chassis this would give me a ground loop hum, yes?
The reason I ask is because the old units were FP twist lock, and as I could not find a suitable exact replacement, used a clamp for mounting the new unjacketed unit. I believe that the clamp is giving me ground loop hum now.
How should I implement a fiber washer to isolate the cap from the chassis? The FP fibreboard washers available are all too small in diameter.
Other materials, methods of mounting the can clamps, etc?
Thanks again guys
Old 17th December 2004, 02:39 PM   #2
riiiiiight,
ok, then, nylon hardware to mount the clamps-check.
now, to find a washer to isolate the case from the chassis-
the cap is 1 3/8" in diameter, the largest fibreboard washer is this exact size...will it work???
if not, i will have to source some type of teflon/plastic washer, and cut to fit.
Old 17th December 2004, 03:15 PM   #3
markp is offline markp  United States
Originally posted by el capitan83
riiiiiight,
Cut a cardboard(not corragated) ring to the size you need. It will work just fine.
If it sounds good... it is good!
Old 18th December 2004, 04:01 PM   #4
...nailed it.
nylon hardware w/ 'surplus' 1 3/8" fibreboard washer.
thanks for all the help, amp is MUCH MUCH MUCH quieter now.
Electrolytic Output Capacitor Kashmire Pass Labs 30 13th December 2007 09:59 AM
electrolytic capacitor source oldheathkitphil Parts 2 22nd June 2007 07:25 PM
Very Newbie Question - Is this a electrolytic capacitor? zBuff Parts 1 11th July 2006 02:05 AM
Electrolytic Capacitor Insulation runeight Tubes / Valves 2 22nd December 2003 06:20 AM
Input capacitor on zen v2. Electrolytic? Arx Pass Labs 1 14th August 2003 08:20 AM
Page generated in 0.07708 seconds (71.80% PHP - 28.20% MySQL) with 10 queries
