Old 15th December 2004, 12:31 PM   #1
GeirW is offline GeirW  Norway
GeirW's Avatar
Default PAS phono. (curcio)
Gday.
Just some quick questions regarding this stage.
1. Do anyone of you happen to know, the commponent values?
(they have been kind enough to distribute the moded. schem.
at dynaco doctor, but none values. it can`t be that simple
that they use old pas values. (turned operation point)
2. Is my humble attemt on the schematic right.
Opinions on the usage of 6922 !? ,
most phono stages/preamp`s i seen, uses ECC83/12AX7.
From what i can read about the 6922, it`s a very good performer,
but is it right in here.
Old 15th December 2004, 12:56 PM   #2
SY's Avatar
6922-oids are an excellent choice for a phono input. Though their gain is lower than a 12AX7, they have (when run properly) much lower noise and suffer much less from Miller effects. The surrounding component values will be quite a bit different between these tubes (12AX7 usually runs at ca. 1ma, 6922 at ca. 8-10ma, and the plate resistances and transconductances are an order of magnitude different).
In my own phono preamp, I use a high transconductance FET at the bottom of a cascode with a 6922-like tube on top. Works a charm, and I get the best of both worlds- the low noise and low gate current of the FET with the swing, linearity, and overload resistance of the tube.
If there's a sucker born every minute, where do the rest of them come from?
Old 15th December 2004, 01:51 PM   #3
alejo is offline alejo  Argentina
Default SY schematic
Hello, SY IŽn search for Phono preamp, plese atach your schematic to see your desing.
thanks
alejo
Old 15th December 2004, 05:13 PM   #4
jan.didden's Avatar
Default Re: PAS phono. (curcio)
Originally posted by GeirW
Gday.
The Curcio design (copyrighted) is available as a reprint from www.audioXpress.com
Jan Didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 15th December 2004, 06:24 PM   #5
SY's Avatar
I haven't posted my full preamp design yet because it uses some tubes and FETs which are no longer commonly available (I built it nearly 20 years ago). But Curcio's design is likely to be quite fine.
Old 15th December 2004, 08:28 PM   #6
GeirW's Avatar
Gday.
ouch.
didn`t notice, that isn`t fair play.
Curcio daniel Sarge Tubes / Valves 36 29th June 2012 11:48 AM
Curcio Daniel II builders? djmike Tubes / Valves 2 18th January 2009 06:16 PM
FS: Dynaco PAS with full Curcio mods beeah Swap Meet 9 17th December 2007 07:56 PM
Curcio Sarah Phono stage: opinions? ad010685 Tubes / Valves 4 8th August 2006 12:30 PM
Curcio or Triode Elec for ST-70 hot rod parts? ultrachrome Tubes / Valves 7 7th November 2003 02:23 AM
Copyright ©1999-2013 diyAudio
