diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Mullard 3-3 Question (http://www.diyaudio.com/forums/tubes-valves/47692-mullard-3-3-question.html)
rdf 14th December 2004 06:00 AM
2 Attachment(s)
My chassis is done but before soldering in the components, does anyone know the history of the two Mullard 3-3 schematics available online? Version A appears to be from the original article and B from some unspecified later date. I've prototyped both and A measured significantly less distortion, and I recall it sounding better too. Anyone know the origins of the B version?
Version A
rdf 14th December 2004 06:02 AM
2 Attachment(s)
And Version B.
ray_moth 14th December 2004 07:19 AM
2 Attachment(s)
I have yet another schema, which I believe to be the same as in Mullard's publication:
rdf 14th December 2004 07:22 PM
Thanks Ray, that's version B with tone controls. Is that from the 1959 'Mullard Tube Circuits for Audio Amplifiers'? Version A is from a Radio Constructors article dated roughly the early fifties. I'm trying to determine which is the newer and, if B, figure out why I found its performance inferior to A.
ray_moth 20th December 2004 01:36 AM
Yes, I built this in 1963 as a record-player amplifier, using Mullard's book. It worked OK but it had only a small eliptical speaker and was driven from a crystal pickup (ugh!), so I wasn't able to evaluate it properly.
rdf 21st December 2004 03:49 AM
Thanks again. Maybe the redesign was due to changes in tube parameters, field failures, or something else unrelated to raw performance. I think Version A's the one then. Some LTSpice results suggest a simple front end change can yield a big payback on A as well. Experiment time!
M Gregg 14th July 2013 07:52 AM
Hello rdf,
What was the outcome of your experiments?
Which circuit did you think was the best A or B and why?
Any thoughts on the level of gain between the two?
Thank's for your thoughts:)
Link,
http://vintageradio.me.uk/amplifier/mullard33.htm
M. Gregg
M Gregg 14th July 2013 02:25 PM
NB,
I have no connection to the link in the previous post, Its just for interest.
M. Gregg
M Gregg 18th July 2013 06:39 PM
OK,
There are two different circuits of the Mullard 3-3 amplifier in this thread.
Has any one built the early version or the late version?
There only seem to be a few changes the anode resistor on the EF86 and the cathode connection on the EL84. (1M and 0.1uf)+ the 1k across the OP Tx.
Please does someone have any ideas why this circuit was modified?
If not does anyone have ideas about circuit operation A verses B?
There must be a reason for the changes:confused:.
If not please have a guess..LOL
M. Gregg
M Gregg 20th July 2013 08:07 AM
Some interesting information,
And PDF files. Sterns etc.
Mullard 3-3 information required - Page 2 - UK Vintage Radio Repair and Restoration Discussion Forum
M. Gregg
Copyright 1999-2017 diyAudio
