I'm looking for a simple and tested headphone amp design that won't turn me down, as this will be my first valve project, I'm totally new to this domain. I'm thinking about a design using one ECL82 or 86 per channel and I found a few schematics, and a few others that I have at home:
http://www.mcamafia.de/tubes/keksdose/cookiebox.htm http://www.avanwaarde.freeler.nl/id13.htm http://www.geocities.com/agalavotti/ecl82.htm http://www.bonavolta.ch/hobby/en/audio/ecl82_4.htm http://www.bonavolta.ch/hobby/en/audio/ecl86.htm http://216.87.144.102/svetlana/TechB...s/No10fig2.gif What do you suggest?
we all love a good ol' stereotype until it's against us |
#2 | |
not that I am an expert either, but all the afore mentioned schematics are amps to drive loudspeakers..? You could of course drive your (low impedance) cans from these, but why so complicated? A good selection of dedicated headamps can be found on "www.headwize.com" , including one from A. vanderWaarde that has been built many, many times. A company named wooaudio even sells commercial headamps that look very close..... rgds, Oliver |
#3 |
Hi Stixx,
From what you are saying, one could understand that conventional valve amps can't drive heaphones. I don't understand why would that be, what makes a headphone speaker so special a load? I'm not talking about electrostatics here.
#4 |
You might wanna have a look here:
http://headwize.com/projects/index.htm Quite a few tube projects, some being real simple.
jens |
#5 |
Headphones usually are in the 32-600 Ohms range, and can of course be driven by a tube amp, that has been explained here on the forum.
Most dedicated headphone amplifiers though get rid of the output transformers being otl-designs, making everything a little easier and cheaper to build..... rgds Oliver |
#6 |
You can build my All-Out Preamp, has tone and bass and four inputs. The cathode follower output is capable of driving my 32 ohm 'phones to a few decibels. Obviously it won't work forever but it'd be a good starting point. 'Specially if you pull out the tone stack and run it straight through instead..(simpler)...
Tim |
#7 |
diyAudio Senior Member
Tubecad's Master John Broskie's SRPP+WCF topology using something like a 6SN7 (SRPP) followed by a 6AS7G/6080 as a WCF at around 300V B+ should make for a nice headphone amp capable of driving even the horror of horrors, the AKG 1000 with aplomb. I should know, I've got one of those monsters with exactly that as an amp so....... See the Aikido blog: AIKIDO SUSHI One caveat, no matter what they say I'd still recommend a good PS with a top quality CLCLC filtering. You'll be stickin' your "oar" in the can, remember? Cheers, ![]() EDIT: Oh, BTW, it comes as close to PP you'll probably ever going to get without resorting to tricky phase schplitterzzzz.
Frank |
#8 |
Thaks for the replies, I found some nice amps on the links you gave me. I can get these tubes form Russia (unused of course) for fair prices:
6N2P (ECC83, 12AX7) 6N23P (ECC88, 6DJ8) 6N8S (12SN7) 6P3S (6L6GC) GU50 (LS50) GM70 Is any of these valves special? Is there any reason for any of these would be preferred?
#9 |
I have built headphone amp with 3x 6N23P (Stereo). It sounds very well and has enough power to drive 32 ohm headphones.
http://headwize.com/projects/showfil...=cmoy5_prj.htm |
#10 |
I've used my PP 6V6 amp with my headphones. I made an adapter to put across the speaker terminals,with an 8ohm resistor across the ouputs,and a headphone jack in parallel. That way the tube amp still has a correct load. It sounds pretty good!
-BUT- Be careful with the volume! The output from a "normal" amp can and will fry ears and headphones! The resistor will absorb most of the power,but even 1W with headphones is ear-bleeding-loud.
| Heaphone Amp | rshep | Solid State | 4 | 23rd July 2009 02:50 AM |
| Heaphone Amplifier question | olvrkrg | Chip Amps | 17 | 19th January 2007 11:19 AM |
| VERY simple heaphone amplifier | sparkle | Solid State | 13 | 4th September 2006 05:34 PM |
| How do you make a Heaphone output on the amp? | Fritzell | Solid State | 5 | 7th July 2005 10:27 AM |
