Bridging
Bridging
Old 13th December 2004, 03:47 AM   #1
virenb is offline virenb  India
Default Bridging
Some manufacturers provide a switch to bridge a stereo valve amp to a higher powered mono amp. How is that done in a valve amp with two output transformers?
Old 13th December 2004, 07:07 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
It isn't. :P
If you must, get two amplifiers with 4 ohm taps and connect them in series (+1 to speaker, -1 to +2, -2 to speaker). Be absolutely sure they aren't grounded together internally!!! (Likely if the amps have NFB.)
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 13th December 2004, 10:52 PM   #3
PeteMcK is offline PeteMcK
Default so what's more efficient????
... a pair of bridged SE amps,
or a mono PP amp?
Pete McK
Old 13th December 2004, 11:08 PM   #4
Sch3mat1c's Avatar
PP if it isn't class A. Always.
In fact, class AB or B or C SE is as efficient... but you can't stand the distortion so it's a moot point.
Tim
BridgingHide this!Advertise here!
here we go again - bridging ZV5 ingvar ahlberg Pass Labs 2 13th April 2008 02:16 AM
How About Bridging SE CLS Tubes / Valves 0 15th May 2007 04:22 AM
Bridging zorb_rules Car Audio 3 28th June 2004 11:01 AM
Bridging Howard Solid State 3 4th January 2004 11:27 PM
Bridging -new way palesha Solid State 1 26th September 2002 04:30 PM
