ECC33, 34, 35 tubes?
Old 29th June 2005, 10:41 PM   #21
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It doesn't look that way to me. EC8010 was comparing an ECC82 to the 6SN7, claiming that the ECC82 had less distortion since the 6SN7 was designed for use in multivibrator type circuits. That's certainly the case, in that 6SN7's appear quite often as time base oscillators in o'scopes and TV sets.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 29th June 2005, 10:55 PM   #22
On Hiatus
SY's Avatar
It's probably past his bedtime (he's rather old and feeble) so he won't comment until tomorrow, but believe me, EC meant it exactly the way I said it.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th June 2005, 01:31 AM   #23
audiousername is offline audiousername  Australia
audiousername's Avatar
If you're on the lookout for noval 6SN7 replacements, the 6CG7 or 6FQ7 are much closer, electrically speaking, to the 6SN7 than ECC82/12AU7.
A quick look at the curves for both, and it's apparent that the 6SN7 has a much more constant than the ECC82/12AU7.
Jason
Old 30th June 2005, 03:38 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I gave Chris some 6FQ7 to try instead of 'AU7 in his ForePlay... he liked. Now i have to dig some out for Don to try in his grounded grid....
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th June 2005, 08:19 AM   #25
Guido Tent is offline Guido Tent  Netherlands
Originally posted by fdegrove
A substitute? For what exactly?
Hi
Well, it is not a "true" substitue, but so far every ECC82 I pulled out replaced by E80CC worked fine. And the distortion is much lower.
cheers
Guido Tent
www.Tentlabs.com
Old 30th June 2005, 01:40 PM   #26
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I obviously wasn't as clear as I should have been. The 6SN7 is the low distortion valve, and the ECC82 the high distortion one.
SY: "Old and feeble?" (Waves walking stick angrily.) Step outside and say that!
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th June 2005, 02:11 PM   #27
On Hiatus
SY's Avatar
Nurse said that you are not to be disturbed until after your nap.
Old 30th June 2005, 05:39 PM   #28
I knew that already. That's why I thought the comment so peculiar. I have a box full of ECC82/12AU7A's, and considered it for a design I'm doing. However, the THD estimates were consistantly horrible. So I gave up on that. So those will have to go on collecting dust.
6SN7's gave much better predicted results. (As did 6SL7's). Also these have a nice "retro" aesthetic that works well with the 807s that I'm using for finals.
www.dolphin-hsl.com
Old 30th June 2005, 07:04 PM   #29
ilimzn is offline ilimzn  Croatia
I only have limited experience with ECC 82 but for me they only worked OK as a follower, and I've seen designs where they were apparently fine for concertina phase splitters.
Someone mentioned the 6CG7 and 6FQ7 which are indeed much closer to the 6SN7, but they are often referred to as the same tube, though in actuality they are not - the similarity is however close enough for them to be almost always interchangeable. I do have one 6CG7 datasheet which claims that apart from it being noval, it is an electrical equivalent for the 6SN7. I don't think there is an noval ECC equivalent to the 6SN7 which is great shame
Regarding the ECC32 and 35, 6SN7 and 6SL7 are almost always mentioned as equivalents.
Old 30th June 2005, 09:32 PM   #30
I've seen them mainly in RF applications: oscillator/buffer stages, push-pull RF class C drivers/frequency multipliers/singly balanced mixers/modulators/product detectors. Other uses include quasi-digital functions such as Schmitt Triggers, astable multivibrators, monostables, or R-S latches. They do have the dissipation rating for this.
Of course, harmonic distortion is not a problem in such uses.
www.dolphin-hsl.com
ECC33, 34, 35 tubes?Hide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 01:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 07:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 12:26 PM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 10:22 AM
