ECC33, 34, 35 tubes?
Old 29th June 2005, 09:08 AM   #11
Tekko is offline Tekko
Banned
I have heard that ECC82 is a 6SN7 but in a noval envelope and that 6SN7 is a ECC82 in a octal envelope.
Old 29th June 2005, 09:15 AM   #12
barretter is offline barretter  United Kingdom
I think you're taking your life in your hands saying that in this forum! By the by, the ECC31 appears to have a shared cathode which means it's not like the 6SN7
Old 29th June 2005, 09:23 AM   #13
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
No.
They're both double triodes with roughly similar mu (15 for ECC82, 20 for 6SN7). At that point, the similarities end. One was designed with audio in mind and has low distortion, the other was designed as a field scan valve for televisions and has high distortion.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th June 2005, 10:36 AM   #14
Guido Tent is offline Guido Tent  Netherlands
Originally posted by EC8010
No.
Consider E80CC as a serious substitute well
Guido Tent
www.Tentlabs.com
Old 29th June 2005, 06:25 PM   #15
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
A substitute? For what exactly?
Frank
Old 29th June 2005, 06:43 PM   #16
EC8010's Avatar
Hello Frank, long time, no see. Yes, I wondered what Guido meant. Perhaps he was suggesting E80CC as a substitute for 6SN7? If so, I can only assume he has a stash of them, because every time I've looked, they've been horribly expensive.
Old 29th June 2005, 06:44 PM   #17
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Hey Frank... good to see your friendly face...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th June 2005, 07:42 PM   #18
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi Frank,
A blue Chimay it will be tonight.
/Hugo
Old 29th June 2005, 09:06 PM   #19
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
I wouldn't say "high" distortion, perhaps "higher" would be more appropriate. After all, a fast break at cutoff and saturation is desireable for a tube intended for astable multivibrator service; not so desireable in a small signal audio amp. However 6SN7's aren't nearly as horrible in that regard as 12AU7A's. I was getting estimated THDs with that one as high as 15% With the 6SN7, I got THD= 4.76% on the basis of V(o)= 232V(p-p). It would be lower for less output voltage. Even the 4.0+% figure is comparable to the measured THD from a funky BJT voltage amp design I once saw on the 'Net intended to reduce THD. The 6SN7 actually does better since most of its harmonic distortion is second order; BJTs produce more higher order harmonics.
Stick to the most linear part of the characteristic, give 'em plenty of headroom, and the 6SN7'll do just fine. No need to get ripped off for those "fancy" VTs. That "Tube World" place is strictly a con-job. Avoid.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 29th June 2005, 09:22 PM   #20
On Hiatus
SY's Avatar
I think EC8010 meant that the 12AU7 has high distortion (which it does) and the 6SN7 has low distortion (which it does).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
ECC33, 34, 35 tubes?Hide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 06:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
