Help!! any good EL3n Push Pull circuits???? - diyAudio
Old 12th December 2004, 08:27 PM   #1
Default Help!! any good EL3n Push Pull circuits????
Dear all,
EL12 also good.
thx
thomas
Old 13th December 2004, 06:49 AM   #2
cogsncogs's Avatar
There are Dozens of them here on this forum! Have a look around! And then post back with any questions you may have about them...
Wayne
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 14th December 2004, 03:55 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
You need to decide on your objective: guitar amp/hi-fi amp/PA amp, and how much power? You can then start to make decisions about the topology, class of amplification and power supply design best suited to your needs. The EL34, for instance, can offer anything from 14 watts in class A triode mode, through 35watts in class AB1 ultralinear mode , to 100 watts in class B pentode mode per pair.
Old 15th December 2004, 11:28 PM   #4
Talking Help!! any good EL3n Push Pull circuits????
Dear cogsncogs & ray_moth ,
I had one pair hashimoto 10K PP output on hand. I hope to build one EL3n PP power amp. I check the spec already. Pair EL3N PP had 9 watt power output is enougn for me.
mainly I was considerate use EF86 input than
6SN7 driver to pair EL3n do u feel good. This is approx like the eico HF60 circuit.
pls advise to me.
thx
thomas
Old 20th December 2004, 03:58 AM   #5
ray_moth's Avatar
Your idea seems OK, although I have no experience with either the EL3N or the EL12, so I can't comment on their performance. Frankly, if I were you I'd go for something which is a bit more mainstream and for which there are many existing circuit designs. On example would be the EL34 in triode mode, which can be used with a 10k PP load for about 14w output - see attached extract from Mullard's original advert for the EL34.
Old 20th December 2004, 12:27 PM   #6
dear ray,
thx for your informations.
Triode for El34 PP had 14 watts output must use 10K PP output trans.
There will be same as the El3N, El3n also use 10K PP had 9 watt pentode output.
any good triode El34 PP circuit to reference.
I will build one amp can change different tube for testing performance.
If the input & driver stage were same will be better!!
thx
thomas
OB push-pull tinitus Planars & Exotics 3 23rd April 2009 12:17 AM
push pull chainenoble Subwoofers 17 28th June 2006 05:35 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
push pull 845 audioman Tubes / Valves 5 30th August 2003 06:53 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 01:23 AM
Copyright 1999-2017 diyAudio
