Single-end... which tube?
Old 8th December 2004, 10:01 AM   #11
audiousername is offline audiousername  Australia
audiousername's Avatar
Mr. Triatic, the 829B and 832As unfortunately (probably due to their relative obscurity) don't have triode-mode curves - I may be wrong, what I'm saying is that I haven't found any.
Since mu g1-g2 is about the mu in triode-mode, and gm doesn't change too much, you can approximate that the 829B will have a mu of around 9 and rp of about 1K, and the 832A will have a mu of around 6.5 and rp around 1K8. Hmm.... well they will work (almost any valve will work). I remember reading somewhere that 1/2 an 832A is similar to an EL84 (functionally anyway) - don't quote me on that though.
Edit: Fixed bad spelling
Old 8th December 2004, 10:21 AM   #12
martinab2 is offline martinab2  United Kingdom
Send a message via AIM to martinab2 Send a message via MSN to martinab2 Send a message via Yahoo to martinab2
Not sure what the cat will make of my latest project: four 211s and four 8008 mercury rectifiers - Ir and uv at the same time
Anyway, I'm hijacking Mr Triatic's thread now so better stop.
Old 8th December 2004, 10:37 AM   #13
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
link:
http://www.audiohobbyist.com/projects/832.htm
i will consider this amp, just have to make some adjustments, i want to use one 832 with separate 6au6wa drivers or maybe just one ECC83 or ECC88 as driver
so i have to use the 832 (or 829?) in SE mode.
www.joddla.net/audio/
Old 8th December 2004, 10:45 AM   #14
Hmm... that's seems like a nice project, and the person who built it obviously spent some time making it look nice as well!
It's a push-pull amplifier though. Unless your OPTs have centre-taps you won't be able to build it without changing it into SE. If your OPTs do, and have been designed for PP operation, they won't handle SE (not well, anyway)
Old 8th December 2004, 10:56 AM   #15
no, they are SE, no centertap..
but i guess i have to lower the voltage somewhat, in PP there is about 230V, according to the schematic.
I dont need high-power, 2-3W would be perfectly sufficient for my purposes 8-) and i suppose that an SE with 832 can give something like that..
Old 8th December 2004, 11:06 AM   #16
Geek is offline Geek
Geek's Avatar
I see no one has mentioned the 6V6. It's quite happy with 9K on plate
Old 8th December 2004, 01:34 PM   #17
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: Single-end... which tube?
Konnichiwa,
Originally posted by Mr. Triatic
I have got a bunch of single-end transformers 9kohm/4ohm, i wonder which tube i can use with these, i was thinking of an EL34 at low voltage maybe?
I would say that these transformers practically have WE205D, 10/10Y/VT25 and RS241 written on them.
Especially the 10Y/VT25 is still readily available NOS and at sensible prices and if you can live with only 1.5-2Watt power Output (same as Decware Zen I'd note) they are IMHO the best sounding option for output valves. I tend to use them with a 2K2 Cathode resistor, 10K Anode load and 460V +B. Drive them with anything you like, they are not that hard to drive, Mu is around 8.
Sayonara
Old 8th December 2004, 01:54 PM   #18
jlsem is offline jlsem  United States
jlsem's Avatar
If you want good sound on the cheap, try military surplus 837's. These are low distortion 12 watt pentodes that cost six times as much as a Mullard EL34 when catalogged in the early sixties, but can be had NOS for less than $10 today. 18K into 8ohms will give the lowest distirtion for these tubes with a pair of cold cathode tubes regulating the screens.
Demostenes (sp?) in Norway probably has a bunch.
John
Old 8th December 2004, 02:00 PM   #19
Fuling is offline Fuling  Sweden
How good are the transformers?
9k/4ohms, sounds to me like something out of old radios.
Not saying old radio transformers canīt be good, but I would think twice before mating such OPTs up with expensive and hard to find NOS DHTs.
Well, since you live here in Sweden you could always order a bunch of 12A6 metal tubes from svebry.se
They practically give them away and they look fine in triode mode.
Old 8th December 2004, 08:28 PM   #20
ok, the transformers isnt that good... but they will be sufficient 8-)
here's my schematic so far:
input please!! 8-)
ps. i guess that B+ would be around 200-250V?
Single-end... which tube?Hide this!Advertise here!
F* amp VS Single Ended DHT tube amp xecluded Pass Labs 15 11th August 2009 07:59 PM
WTB: Single KT88-EH tube quadtech Swap Meet 0 17th March 2009 01:31 PM
Using single tube of Dual wrenchone Tubes / Valves 4 1st February 2009 03:54 AM
WTB: Single Ended tube amp bepatient Swap Meet 4 29th January 2006 08:11 AM
WTB single EAR509 tube amp icarex69 Swap Meet 0 18th December 2003 12:49 PM
Copyright ©1999-2017 diyAudio
