diyAudio Sponsor
Old 7th December 2004, 05:08 PM   #1
Mr. Triatic's Avatar
Default small poweramp with 12AH7 and 6AU6WA...
hi there!!
are there any realistic chance to get an working amp out of these tubes?
(12AH7 and 6AU6WA)
with a single-end transformer 9kohm/4ohm rated approx. 8-10Watt ??
any helpful schematics out there?
i know that 6au6wa have been used for audio eventhough its made for oscillators and similar.. but the 12AH7?
-any help appreciated!!
www.joddla.net/audio/
Old 7th December 2004, 08:07 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hmmm, 12AH7 looks like a weak 12AU7. Didn't see any curves for it. 6AU6 can be used for output, if you want to parallel about 10 or 20 of them. Which is unlikely. :P
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Curves for 12AH7 jane Tubes / Valves 0 1st May 2009 11:03 AM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
6AU6WA triode connected as a line amp? grhughes Tubes / Valves 13 10th October 2006 01:17 PM
Page generated in 0.06185 seconds (67.28% PHP - 32.72% MySQL) with 10 queries
