ELC7? I need help to identify this valve
Old 6th December 2004, 11:14 AM   #1
pingfloid is offline pingfloid  Thailand
pingfloid's Avatar
Question ELC7? I need help to identify this valve
I am rebuilding an old guitar amp, but I have trouble to identify the output valve. There is a mark "ELC7" written with a pen, but I can't find the specs for that valve. I enclose the picture.
The amplifier have a EZ81 rectifier and a ECC88 pre-amp. The supply transformer is 300+300V.
Any clue?. Thanks
Manuel
Old 6th December 2004, 11:15 AM   #2
pingfloid's Avatar
...and a ECC88 pre-amp
Sorry, I mean ECC81
Old 6th December 2004, 03:29 PM   #3
Fuling is offline Fuling  Sweden
Looks to me like an ECL80-something, probably 82 or 86.
Old 6th December 2004, 06:37 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
How many pins ?
Perhaps a perspective effect, but looks like a 6AQ5
Old 7th December 2004, 02:19 AM   #5
martinab2 is offline martinab2  United Kingdom
Send a message via AIM to martinab2 Send a message via MSN to martinab2 Send a message via Yahoo to martinab2
If it has 7 pins then 6aq5 / EL90 seems like a fair possibility. 9 pins? I have a 6bw6 and a 6cl6 with the same rounded anode style although they look a bit shorter than the one in the photo. All the ECL series valves I've seen have a different style of anode construction with a more rectangular shape and fairly wide flanges joining the two halves.
Old 7th December 2004, 12:14 PM   #6
pingfloid's Avatar
I forgot to mention... It's 9 pin.
Here is a closer picture
Old 8th December 2004, 05:16 AM   #7
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Looks like an EL84 to me.
Have a look and see if you can identify the socket connections, which pins go to the heater, cathode, plate etc.
ELC7? I need help to identify this valveHide this!Advertise here!
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Can you identify this cap? Richidoo Parts 4 13th March 2009 11:53 PM
Please, can someone help me identify these ? juma Multi-Way 5 11th April 2008 08:14 AM
Identify This.... EchoWars Solid State 6 2nd August 2003 12:24 PM
Copyright ©1999-2017 diyAudio
