EL84 SE design recommendations? - Page 29 - diyAudio
Old 9th April 2009, 04:35 AM   #281
rickl is offline rickl  United States
Zekk,
Click on Alex's name to get his profile and click on his home page. you will see the RH84 link.
You will like it.
rick
searching for jazz and a little libations.
Old 9th April 2009, 12:51 PM   #282
korneluk's Avatar
Default Re: Desperately Seeking RH84SE Schematic.
Originally posted by Zekk
Guys ... where can I get hold of Alex's RH84SE schematics?
follow the link:
http://www.tubeaudio.8m.com/RH84/rh84.html
Old 9th April 2009, 12:59 PM   #283
Empee is offline Empee  Netherlands
Empee's Avatar
Mr. Kitic,
(hopefully you will read this)
are you planning a revised version on the RH807,
converting it in RH-2nd generation topology ?
Got all pieces and about to start building the RH807....
Cheers !
Empee
In the end, all is good
If it's not good, it's not the end
Old 9th April 2009, 08:33 PM   #284
Banned
Yes, I am reading
Well, not exactly: the 2nd generation of amps is simpler in the schematics, but that is paid by a limited (at least currently) number of combinations that make sense.
Actually, the KT88/6550 make sense as it gives lots of power you would otherwise look for in a (relatively dangerous high B+) 211/VT4C/845 amp... the 300B version makes sense because everyone seems to be fascinated with the tube (maybe because of the price).
So, for now, the 1st generation amps will not be converted to 2nd generation. Maybe in the near future there will be more 2nd generation amps with different output tubes... if the schematics generates the success achieved by the first generation.
Alex
Old 9th April 2009, 08:49 PM   #285
Empee's Avatar
Hi Alex !
Okay, understood.
I will proceed on the RH807 as it was drawn up by you.
One more thing though;
about fixing the voltage on g2 via a voltage divider in the RH807,
what values of resitors and by-pass cap for the lower resistor
do you advise in the "standard" RH807 schematic ?
Empee
Old 10th April 2009, 09:18 AM   #286
Banned
I actually DO NOT ADVICE fixing the voltage
I believe this was a question about a "voltage divider" to fix the voltage of g2... because in that case you would need a "lower resistor" and the appropriate bypass cap to provide a different AC path.
The RH schematics are designed in such a way that they function regardlessly of B+ (of course, if the value is extremely high, or extremely low, that is a completely different issue). I like to think of it as "in-built reliability" or "novice-proof" design.
Old 10th April 2009, 10:58 AM   #287
Empee's Avatar
aha!
so it's just a matter of a designing a GOOD psu and let it all float along...
Will do!
thanks for your advice!
As always;
Cheers !
Empee
Retubing my amp (EL84, ECC81, ECC83) - Tube recommendations? horace Tubes / Valves 18 18th December 2007 01:54 PM
6L6 PP Design Recommendations? cantskienuf Tubes / Valves 13 13th September 2004 06:47 AM
Recommendations on a simple design? G Tubes / Valves 42 8th August 2003 07:34 AM
Tentative EL84 SE Design. G Tubes / Valves 84 1st January 2003 01:43 AM
Copyright 1999-2017 diyAudio
