| diyAudio Sponsor | ||
#11 |
Konnichwa Guys,
Thanks for the above. I also sat down and read thru' the entire "Partial Feedback" thread over the weekend. Also grabbed a copy of the Citation II circuit and had a good long look and reread the RDH section on feedback. KYC 's sig. there says "There are two types of people in the world - those who get it and those who don't". I'm more of the view that there are three (3) types of people in the world - those who can count and those who can't. I don't get it ALL but I'm learning. What I'm looking for is a direction to mod "bog standard" Menno Vandervenne amps, the 12AU7 common cathode amp - direct coupled concertina phase splitter and 2 pairs of "Winged C" Svetlana EL34s (Ultralinear Mode) with PAT 4006 (Raa=2100 Ohms to 5 Ohm ). I've tried global feedback on this and other Class AB1 UL PP amps - with various quality output transformers and in EVERY instance where I've "tuned" global feedback for sound I've arrived at 5, 6 or 7dB of global feedback. Anymore kills imaging. Thanks again, Ian |
#12 | |
John |
#13 | |
Previously: Kuei Yang Wang
Konnichwa
Due to the nature of the circuit feedback from the output valves anodes to either Output Valves grids and/or anywhere else in the circuit is not applicable. So you are limited to a global loop, no matter how problematic this becomes. The other option would be to completely re-design the Amplifier with a different driver circuit. One option keeping the current layout might be a FET/12AU7 differential cascode with feedback from the anodes of the output stage to the source lines of the FETS.... Sayonara |
| Effect of tweeters on ohm impedance? | Flyin11 | Car Audio | 3 | 28th February 2008 05:46 AM |
| Cathode feedback and input impedance | abj1 | Tubes / Valves | 2 | 31st January 2007 01:06 AM |
| Calculating shunt reg source impedance | lndm | Tubes / Valves | 21 | 6th January 2007 11:27 AM |
| Amplifier's impedance effect on XO | K-amps | Multi-Way | 11 | 30th December 2006 05:32 AM |
| general question about feedback, input impedance, and noise | nobody special | Solid State | 8 | 29th August 2005 09:23 PM |
| Page generated in 0.08584 seconds (76.21% PHP - 23.79% MySQL) with 10 queries |
