diyAudio Sponsor
Old 11th December 2004, 06:23 AM   #31
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Y'mean a zobel? For HF crud? Depends on where it is. I'd make it around a quarter of the output stage power if you have it on the OPT. More if you want to be testing HF response at any reasonable power level for any length of time!
Fragman, the problem with chasing down motorboating is, because it's inside a loop, every point in the chain (including the effect it has on the PSU, which IMHO is the cause, phase shift oscillator style as I mentioned previously) shows the signal.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 11th December 2004, 08:38 AM   #32
waner is offline waner  Sweden
Hello
What is a zobel (I`m not that good on english)?
The wattage for the anti ringing resistor is 1W
Mattias
Old 11th December 2004, 07:17 PM   #33
Sch3mat1c's Avatar
A zobel network is a resistor in series with a capacitor. Its function is to dampen with the resistor when the frequency is above what the capacitor allows. At low frequencies, the reactance of the capacitor is large and the resistor has no effect. At middle frequencies, the resistance and reactance are about equal to the impedance of the circuit and it begins to damp the system, without causing undue phase shift as a plain capacitor would. At high freuquencies the reactance is small and disappears, applying the resistor directly to the circuit, damping it fully.
Tim
EL34 in class AB2 triode mode push-pull? ray_moth Tubes / Valves 29 8th March 2009 07:34 PM
Wanted. Simple EL34 Push Pull Design jack firebrace Tubes / Valves 43 2nd December 2008 10:18 AM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 11:52 AM
EL34 Pentode in Push-Pull! Guijs Tubes / Valves 65 18th January 2006 03:02 PM
Troubleshooting EL34 push pull amp psysjal Tubes / Valves 12 15th October 2004 04:21 AM
Page generated in 0.08917 seconds (78.02% PHP - 21.98% MySQL) with 10 queries
