diyAudio Sponsor
Old 30th November 2004, 02:11 PM   #1
Lightbulb simple 6v6 push-pull schematic ?
Hi , i want to built a simple push-pull 6v6 power amp. is there a simple schematic ? does somebody have a good one to suggest?
Old 30th November 2004, 05:25 PM   #2
Send a message via AIM to DigitalJunkie
Here's a fairly simple,nice sounding PP 6V6 amp.
http://www.users.qwest.net/~ptaylor/...V6amppage.html
It's an amp from an old console that I rebuilt,and tweaked a bit.I get right about 8W per channel before any real signs of distortion(Forget how much when triode-wired,probably 3-4W),I think it starts clipping at about 10Wpc.The output transformers are sorta small,but it still has some impressive bass response for a smaller amp.
With some larger/better output transformers I would expect it would be pretty nice..
Old 30th November 2004, 06:29 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I've got some. Lemme see here.
http://webpages.charter.net/dawill/t...its/6W6_PP.gif (says 6W6 but works better with 6V6's )
http://webpages.charter.net/dawill/t...Stereo_6V6.gif (commercial Magnavox stereo amp, I wouldn't use it actually)
My computer's current left channel monoblock:
http://webpages.charter.net/dawill/t...nkenhouse.html
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 30th November 2004, 07:53 PM   #4
jazz is offline jazz  Netherlands
Hi there,
Here's another one. It's based upon using the trannies from an old lafayette la224B (8k a-a). It comes from an article in the dutch mag 'audio&techniek'. I believe the author is a member here.
Old 30th November 2004, 07:55 PM   #5
darn how do i get that jpeg posted! right size, attached it, no show!
got it, use the edit function
Old 30th November 2004, 08:02 PM   #6
You just have to attach the file by clicking on browse, beside of the attach file... the file will be just fine...
Old 30th November 2004, 08:13 PM   #7
jim is offline jim  Belgium
Default Amp experience.
I built both the Dutch schematic as posted above as well as one from l'Audiophile which both sound excellent.
You won't be disappointed when build one of these.
Greetz,
Jim
EL34 simple push pull class B : why 100W ? bozole Tubes / Valves 13 1st July 2009 05:26 AM
Wanted. Simple EL34 Push Pull Design jack firebrace Tubes / Valves 43 2nd December 2008 10:18 AM
simple guitar push pull amp dan _s Tubes / Valves 8 12th August 2008 01:02 AM
A very simple push-pull project darkfenriz Solid State 5 6th September 2004 09:26 AM
schematic for a push pull EL 509 Antonio Tucci Tubes / Valves 13 10th March 2004 11:11 PM
Page generated in 0.08573 seconds (76.58% PHP - 23.42% MySQL) with 11 queries
