Valve Warmer/Distortion PCB
Old 29th November 2004, 05:35 PM   #1
sleepingsword is offline sleepingsword  United Kingdom
Default Valve Warmer/Distortion PCB
Hi
I would like to have made a type of vavle preamp.
This is what i want from it
Stereo Line Input (2x bal 1/4 inch jack) with Gain Control
A pair of 12AX7 'valves' (or similar/better, Im open to suggestions)
Stereo Line Output (2x bal 1/4 inch jack) with Output Level Control
I do not need Hi Z input
I do not need Phantom
(so isit really a preamp?)
It can be mains powered but has to be low noise.
The guy who can make it for me needs a PCB diagram so can anyone suggest a place I could find one?
Many Thanks
Old 2nd December 2004, 02:15 PM   #2
*sho-ryu-ken! bump*
Cant anyone help the Tube Noob?
Old 2nd December 2004, 03:57 PM   #3
Brett is offline Brett
Brett's Avatar
I'm not sure what you're trying to accomplish, so it's hard to suggest anything. How much gain? How dirty? What type of dirty?
But first of all, it's going to be so simple no matter what you do that a PCB is a big waste of time, point-to-point construction would take me less time to get it built than simply designing the PCB. With P2P you can quickly and easily change components and futz around with it until you get what you want.
Old 6th December 2004, 06:44 AM   #4
I pretty much want to use it for distortion and to add 'warmth' to some soft synths
it will be used with a delta 66 soundcard as an insert effect in cubase
donít want guitar style distortion but I do want it to get pretty heavy.
so I assume I want lots of gain on both ends, but no need for any preamps
I donít know if the tubes can or need controlling,
I assume you have; input, tube, then output. the output controls/drives the tube?
I hear it will need some sort of cap to keep it noiseless
I am not capable of taking a current PCB and adapting it for my own needs, nor am I skilled enough to tell if the one im looking at is the one I need (though I am trying to learn...)
thanks for ye help!
Valve Warmer/Distortion PCBHide this!Advertise here!
6M5 valve PeteMcK Tubes / Valves 16 3rd July 2017 08:19 AM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
Why does a sub play louder in warmer weather? xplod1236 Subwoofers 21 28th May 2006 11:47 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
