| diyAudio Sponsor | ||
#31 |
Unless that's a slit in the plate, it looks like it's glowing
Oh well, ratings shmatings My Revision 3, the proper blue glow ![]() Well... a little overexposed. And blurry. Not bad for a dark shot though...
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#32 |
Ok guys, I did a couple of shots of an E34L in a normal operating condition taken in the dark. I manipulated the pics in photoshop to highlight the blue glow and to cut down on image size. I could've increased the bias current to make the blueglow more prominent but...
The first pic shows the blue glow inside the tube. You can see it through the slots. Wayne |
#33 |
And in the second pic you can see an 8 shape on the inner surface of the glass. It's kind of hard to see...
This is absolutely normal guys! When the tube was new this glow was more prominent! So don't fret! I can't stress this enough: If it's a pretty blue it's normal; So crack a beer and sit back and ENJOY the SHOW! If it's purple or pink and floats around that's bad and you will get a lot of noise that's not musical (to most of us!) coming from your spkrs! Wayne |
#34 |
#35 |
Look carefully at the septar sockets.
Solid-state blue glow... ugh... |
#36 |
OMG!
Well it just goes to show how far some people will go to get that Blue-Glow! Wayne |
#37 |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#38 |
Waveborne: that's a good one of a bad one; Try another 88; a serious damaged screen:
On warm up most of the blue was on one side; with a small concentrated area lower left. The other pic is ++ current half tube rating, the electron beam is one sided. (If you donna turn up the juice you won't see all the defects). Symptoms; high thd. Motto. Use screen resistors !richy |
| Glow tube shunt reg stability | mach1 | Tubes / Valves | 1 | 28th April 2009 05:50 AM |
| Glow Tube (0B2) Help | dsavitsk | Tubes / Valves | 16 | 27th October 2008 08:16 PM |
| New WE 300b's blue glow | TubeHound | Tubes / Valves | 26 | 31st March 2003 01:22 PM |
| Page generated in 0.08650 seconds (77.67% PHP - 22.33% MySQL) with 11 queries |
