Old 24th November 2004, 02:05 AM   #1
lpd is offline lpd  Canada
Default Dynaco Pas
Here's a couple shots of a Dyna Pas modded that I picked up recently. It has a bizarre outboard power supply with the stock transformer, a filament transformer and a choke. In the unit it has all switches bypassed and a new volume switch and mods on the power supply filter capacitors with diodes ect. The boards are original and I might replace them with upgraded capacitors, and the rca's on the back are stock which I will replace as well. Haven't listened yet but I will post a review at a later date. Right now I'm going to clean it up and check all voltages...anyone seen a power supply like this?
Old 24th November 2004, 05:05 AM   #2
Bill Fitzpatrick's Avatar
With your posting photos approaching a half a megabyte in size I'm not going to even talk to you.
Old 24th November 2004, 11:21 AM   #3
cogsncogs's Avatar
751kB total! Jeez! Took 7mins on my dial up, At least 10 I think, lost track of the time! Watch the size of your pictures. Most of us will get bored and switch threads!
Wayne
Old 24th November 2004, 03:09 PM   #4
Sorry guys, I resized the originals, but the server seems to save them and I can't edit my post.
Peter
Old 24th November 2004, 03:23 PM   #5
markp is offline markp  United States
The powersupply looks like its for an amp not a preamp! Looks like a 5AR4 or similar as opposed to the little skinny rectifier tube that comes stock. Overkill to say the least. Change out all the caps and resistors and you will be very happy with it. All the noise will be gone(well almost!). Use only metal film resistors and caps, not carbon comp unless you like the hiss and overly warm sound. The big choke is a nice touch but again overkill. There is also a seperate filament transformer which can be switched on seperately and save tube life.
If it sounds good... it is good!
Old 24th November 2004, 07:49 PM   #6
The rectifier is a 6K5. It has a couple chokes for filter supply. The capacitors on the line stage are Aerovox, Astron, and Sprague Black Beauties. I suppose I should replace them with newer ones (although they don't appear noisy), and the carbon resistors. The volume knob is a stepped attenuator but appears to use carbon resistors (not sure why)? Any ideas why use carbon comps for a stepped attenuator...it doesn't appear to be a kit either.
Old 24th November 2004, 09:05 PM   #7
That is a stereo width selector that has narrow to wide separation. I think it's a 6X5 rectifier.
Old 24th November 2004, 09:38 PM   #8
Your right the rectifier is a 6X5. The volume switch is a stepped attenuator though. The blend switch is disconnected.
Old 24th November 2004, 09:39 PM   #9
Somebody went mod-crazy on that volume control!
Old 24th November 2004, 09:51 PM   #10
jazz is offline jazz  Netherlands
Hi Peter,
First of I don't have any experience with units like you have but I just couldn't resist making one remark. MarkP suggested to swap resistors and caps straight away but I wouldn't go that far just yet (sorry markP, not to offend). Those resistors sort of resemble 'Allen bradley' resistors to me (only from the pics i've seen) and those seem to be rather highly regarded. So until you're quite certain what they are i'd be rather carefull with em. I don't know what kind of caps those are but they just might be some of the well appreciated paper in oil caps. I'd try testing them for leakage first, before you trash them. In other words someone has obviously modded this unit and I wouldn't disregard his mod's straight away, I'd listen to it first (after checking those caps etc.) and then go on.
As said before i just couldn't resist to be cautious
Joris
Dynaco ST-120 botrytis Solid State 21 18th August 2012 03:30 AM
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Dynaco ST-410 Amp Creelove Solid State 7 22nd July 2010 05:08 AM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
dynaco st 70 c3 dcb50 Introductions 1 30th September 2008 11:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
