feedback resistor - diyAudio
Old 23rd November 2004, 07:26 PM   #1
Default feedback resistor
Hi, i need some help ! anybody have a good web site that told HOW TUBE AMP work... ?
Also where is the feedback resistor on this schematic.
Old 23rd November 2004, 08:07 PM   #2
The feedback resistor is the 10k resistor in the upper part of the schematic, in parallel with the 0,0001uF capacitor
leroy
Old 23rd November 2004, 08:19 PM   #3
Thanks.... it's true that if i remove the feedback resistor i will have more gain, more distortion ?
Old 25th November 2004, 03:53 AM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
Yes, if you disconnect the feedback resistor, you'll get more gain and more distortion and probably more noise. You may also notice a "hump" in the frequency response, i.e. middle frequencies amplified more than bass and treble frequencies and also a lower damping factor, which might make the bass less clearly defined and a bit "boomy".
chipamp resistor feedback fellic Chip Amps 13 1st June 2014 08:50 AM
feedback resistor and temperature AndrewT Solid State 17 12th February 2009 03:39 PM
how to calculate feedback resistor Lico Tubes / Valves 7 9th June 2004 05:41 AM
feedback resistor.......? tbla Chip Amps 0 29th August 2003 03:27 PM
1m feedback resistor jkeny Chip Amps 0 20th August 2003 10:58 PM
Copyright 1999-2017 diyAudio
