Grid stoppers? - diyAudio
Old 23rd November 2004, 07:54 PM   #1
Default Grid stoppers?
Could someone point me to a place on line covering grid stoppers and how to choose value for a certian cutoff. I want to use them to roll off high end but do not fully understand the process. Thanks.
Old 23rd November 2004, 09:28 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I believe the concept is to counter feedback before the tube by shunting such HF against the miller C.
Liberal use of plate zobels can quash things as well.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 23rd November 2004, 10:07 PM   #3
Thats what I want to learn, How to pick the correct resistance to work with the miller capacatance to make an RC filter to roll off high frequencys above 20Khz or so.
Old 23rd November 2004, 10:14 PM   #4
SY's Avatar
Aha! Well, if you want grid stoppers to do that, it's just a simple use of the formula f(-3dB) = 1/2piRC, where R is total source resistance (output resistance of driving stage plus grid stopper) and C is total load resistance (grid capacitance plus stray plus Miller capacitance).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd November 2004, 10:39 PM   #5
Geek's Avatar
I've done some pretty scary breadboard layouts and found that a 1K resistor as close to the tube socket as possible is a pretty good fix-all
Old 24th November 2004, 04:42 AM   #6
Using grid stoppers to cut down the treble might not be such a splendid idea (except maybe in guitar amps), as you would have to use a very big value, in most cases, to get any significant effect (I'm not talking about the subtle changes you might get with different smaller values...). Too much resistance in series with the grid will result in distortion due to modulation of the tiny grid current variations over a cycle; Morgan Jones cites ca 60k (if I remember correctly) as the value where he started to get a measurable increase in distortion (with the valve he used - may have been a 6S45P?).
I think an rc filter before the grid (and, preferably, a grid stopper) would be a better idea (except as noted in guitar amps, where the added distortion due to a huge grid stopper (esp. in overdrive) might be interesting.
Anyway - good luck; whatever works works.
Old 24th November 2004, 11:41 AM   #7
reaction's Avatar
The grid stop resistors are not obligatory but are nice anti-oscillating/parasitic solution in some circuits.
About 300 ohm decent ones (Dale RN, Riken) are ok.
Old 24th November 2004, 11:55 AM   #8
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Grid-stopper values are very much "suck it and see." They aim to damp the resonant circuit formed by valve capacitances and inductances in the grid/cathode loop. The main thing is that the resistor body should be as close to the valve pin as possible. Carbon resistors are a good idea because the higher resistivity of carbon means fewer turns are needed and they have lower inductance. In general, valves with higher mutual conductance are more likely to oscillate, so directly heated triodes are almost immune, but frame-grid valves designed for UHF use (ECC88, 6C45 etc) are more susceptible. Good RF layout (short wires, ground planes etc) reduce the problem. With really good layout, it's possible to get the grid-stopper down to <100 Ohm, but Mullard used between 1k and 4k7 for EL34 and EL84 power pentodes in ultra-linear mode. Once you start paring the value down, you need a good oscilloscope to monitor the anode of the valve concerned whilst provoking it with a square wave to make sure that it's not oscillating.
Most people just use a larger value than strictly necessary in the knowledge that if it's too big it will definitely damp oscillation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th November 2004, 01:55 PM   #9
analog_sa's Avatar
"suck it and see."
You can say that again. I never take design rules for granted and have often found i prefer the sound without a grid-stopper. No idea if this is simply because another lousy resistor is not in circuit or the grid prefers seeing lower driving impedance but even on problematic valves like 6S45P i'd first make sure that grid-stopper is really needed.
Old 24th November 2004, 07:43 PM   #10
Thanks for your help. I may look at a different way then. I,m just hearing some sort of distortion with some sibilance and real high picalo flute parts.
Choosing proper g2 grid stoppers for SE UL..? JandG Tubes / Valves 3 2nd September 2008 02:53 AM
Please explain grid stoppers.. JandG Tubes / Valves 7 2nd November 2007 08:21 AM
is it really required to use carbon comp for grid stoppers? jarthel Tubes / Valves 23 22nd October 2006 07:14 AM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 02:59 AM
Values for grid stoppers for 6922... JoeBob Tubes / Valves 17 28th March 2003 05:54 AM
Copyright 1999-2017 diyAudio
