Old 27th November 2010, 02:10 PM   #31
Hey John,
not thomas but he did help me with this a number of years ago. Essentially you need to add an additional resistor (R25) above the .126u 68K combo and lower the value of the 45mhy inductor.
dave
Old 27th November 2010, 03:24 PM   #32
Originally Posted by Vinylsavor View Post
Hi!
A while back I shared a design of a full function preamp with RC RIAA phonosection on AA. I call it the Octal preamp. It uses 6SL7/6N7/6SN7 tubes.
If there is interest, I'll open a thread about it and post the schematics
Best regards
Thomas
Thanks, I am always interested in seeing stuff like this. I had gotten it in my head that I wanted to try one using the 12A_7 series of tubes just for giggles. I can't find the latest version of the schematic right off hand but it is essentially like this with a 12AY7 instead of 12AT7 for the lower element of the mu-follower.
If We The People refuse to hear the truth we will be ruled by liars.
Old 27th November 2010, 04:25 PM   #33
Hey guys,
This an example of compensation that I simmed. The filters are from a Neumann 1974 cutter. It will still be approximation as Neumanns is 2nd order. If you have Daves chokes, Lundahls or a EQ-2L you can adopt it. The blue is uncompensated.
Old 30th November 2010, 12:59 AM   #34
hey lars,
surely a few value tweaks can fix the minor drop at 5-6khz. In some circles that -0.2dB would surely make the results unacceptable :-)
dave
Old 30th November 2010, 05:29 AM   #35
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can borrow my test signal (please return it after you done!):
http://wavebourn.com/gallery/riaa/Re...Sweep-RIAA.wav
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 30th November 2010, 07:30 AM   #36
Hey Dave,
You can stay well below 0,1dB with 45mH, this has been showed at your place. What I now showed was an example of the difference between Neumann and std. Will surely be aproblem to do it IRL due to component-tolerances.
Below is another sim that shows the differences between std and Neumann. The *.asc is also in a thread at your place. Blue is Neumann-corrected. Now check tolerance .
phonostage with 150VDC B+ alexg Tubes / Valves 9 18th August 2007 01:13 AM
rjm 2 tube phonostage hacknet Analogue Source 6 10th April 2006 05:27 AM
Freaky Whistle in Guitar Amp Trout Tubes / Valves 47 9th January 2006 05:42 PM
phonostage design lt cdr data Analogue Source 1 20th April 2005 09:48 AM
diy MC-phonostage Onvinyl Analogue Source 25 30th November 2002 04:24 PM
Copyright ©1999-2013 diyAudio
