#2 |
Congrats, looks like something the cat ... ah, nevermind, the stuff i build mostly looks the same. The RCA phono is not my favourite but others seem to like it. If you like the sound a lot as is, then it's probably worth swapping caps, etc. If you really don't like it, no amount of cap-treatment will do much good. IMO only very good topologies justify expensive parts.
good luck |
#3 |
thanks!
can anyone recommend some circuit mods? |
#4 |
Those caps look a LOT like Suzuki caps - even though they have a different name as far as I can see. You can read more about Suzuki caps here: http://stiftsbogtrykkeriet.dk/~mcs/Sansui_500.html
If they are the same, you should replace them at once - at least the ones that are supposed to block DC. Otherwise you'll kill the tubes. And those Telefunken tubes are worth saving BTW - don't let bad caps kill them ![]() Best regards, Mikkel C. Simonsen |
#5 | ||
diyAudio Senior Member
A Lafayette made in the land of the rising sun perhaps? Cheers,
Frank |
#6 |
Ok, finally got this thing in the mail.
The caps are "King oil caps". They look like the suzukis... The transformer buzzes something fierce, but the signal sounds fairly quiet. The tubes look fake to me... long plates but don't have the diamond on the bottom of the tube. I have no idea if the caps are bad, but the sound of this preamp sounds pretty good. The midrange is a bit harsh, but the highs are superb. The bass is a problem though. There is NO bass. Could be bad tubes I guess, but wouldn't that affect the high frequencies more? or does this point to bad caps? Any help would be appreciated. Thanks |
#7 |
Account Disabled
No bass-bad caps.
If your caps are old replace them immediately! I can't see your images.Maybe there's a problem with my connection
#8 |
thank you for your reply.
OK, I will replace the signal caps. On the caps, there is a black line on the end of the can, is this the inner foil lead? Where can I find a replacement power supply cap??? It has 4 posts, 40, 20, and 20 uF at 150wv. |
#9 | |
Account Disabled
It's more important to replace PSU's caps than signal caps.
Maybe signal caps are OK. Quote:
There are more brands out there that I don't remember. Still, can't see your images.
#10 |
I just measured the output RCA's
23volts out of the right channel, and 16volts out of the left channel. That's bad, right?
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| Which phono preamp ? | yagoolar | Tubes / Valves | 5 | 26th January 2005 10:50 AM |
| MC phono preamp | Vortex | Tubes / Valves | 29 | 29th March 2004 10:39 AM |
| Phono Preamp. | victor | Pass Labs | 0 | 24th October 2001 07:11 AM |
