Lafayette Phono preamp. - Page 2 - diyAudio
Old 24th December 2004, 05:45 PM   #11
analog_sa's Avatar
23volts out of the right channel, and 16volts out of the left channel.
Is that with the new output caps?
Old 24th December 2004, 05:47 PM   #12
mattjk is offline mattjk  United States
I'm so dumb. I had the switch set to the tape head. With it in phono, it is 14volts even. Don't know why the tape is so off though... maybe the switch contacts are bad.
Old 24th December 2004, 07:44 PM   #13
frugal-phile(tm)
planet10's Avatar
I have a mono one of those... did yours come with the Telefunken's in the picture? In decent condition those are valuable.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th December 2004, 08:04 PM   #14
yes, it came with the telefunkens. How much are they worth? Mine is in mint condition.
Old 24th December 2004, 09:46 PM   #15
frugal-phile(tm)
planet10's Avatar
to sell for the max they need to be tested & ideally have similar date codes & the same factory code... be careful if you clean the bottles -- the silkscreen is delicate. Double check that they have diamonds on the bottom.
Are the ECC83s... i've seen those go for $40-80/pr on eBay.
dave
Old 24th December 2004, 10:14 PM   #16
Ahh, ok. thank you.
The tubes were tested and matched.
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
Which phono preamp ? yagoolar Tubes / Valves 5 26th January 2005 11:50 AM
MC phono preamp Vortex Tubes / Valves 29 29th March 2004 11:39 AM
Phono Preamp. victor Pass Labs 0 24th October 2001 08:11 AM
Copyright 1999-2017 diyAudio
