What do you guys use to drill holes on chassis?? - Page 2 - diyAudio
Old 19th November 2004, 12:40 AM   #11
jlsem is offline jlsem  United States
jlsem's Avatar
Since I only use 1/8" and 3/16" thick aluminum for chassis, hole saws and step drills work just fine. The less run-out your drill press has, the better your results with a step drill. ALWAYS use a cutting fluid specified for aluminum when drilling holes, you won't regret it. I also finish the inside of holes made with a hole saw (1" dia. to 2" dia.) with a small, inexpensive drum sander.
John
Old 19th November 2004, 01:34 AM   #12
sanford1's Avatar
I've used uni-bits with good results.
Old 19th November 2004, 02:08 AM   #13
Brett's Avatar
I'm lazy. I either use scrap thin ply for protos, or when it's finalised I draw it up and take it to a small metalshop and get them to do it. Look in the yellowpages, there'll be places in most large cities that do large AV and security CCTV installs and will have most connector holepunches and can do the others. I like front panels and top plates out of thick aluminium or brass. It's usually not expensive and you get pro results.
Old 19th November 2004, 07:51 AM   #14
Enzo is online now Enzo  United States
In the USA anyway, you can get Greenlees from ANtique Elec. For $30-$45. My Greenlee 1" has been with me now for over 45 years. My 3/4 almost as long, and the 1-1/8 is just a kid at 25 years plus. I think the prices are reasonable for that kind of life.
Antique is www.tubesandmore.com
Also look at W.W.Grainger www.grainger.com
Old 19th November 2004, 02:23 PM   #15
Fuling is offline Fuling  Sweden
For some of my more serious projects Ive had help from my brother to cut the holes. He runs a wire EDM at work, and that machine is just perfect for making chassis!
You can cut PERFECT holes in anything from thin aluminium to several inches of hardened steel...
Old 19th November 2004, 02:33 PM   #16
Coulomb is offline Coulomb  England
Coulomb's Avatar
www.mcmastercarr.com
I like to stay current!
Old 19th November 2004, 02:49 PM   #17
I'm also fortunate, as mr Fuling above, in that i can call on help from others. I can warmly recommend WATERCUTTING your chassis, it will give you very nice results, without the hassle. My brother-in-law made a top plate from my autocad drawing, out of nice 4mm aluminium.
Rgds
yac
Old 19th November 2004, 03:09 PM   #18
Nothing beats proper machinery when it comes to cutting round holes.
My brother talked about making a set of hole punches in the right sizes for the most common tube sockets, I guess hes a bit tired of programming that EDM. The way he explained it seemed easy enough to make a few, and he has the skills and tools so why not.
Old 19th November 2004, 03:58 PM   #19
markp is offline markp  United States
If you have the access to the hard steel and a machine to form the cutter out of it, it would still be cheaper to buy one. You need a really good roller bearing and a very high grade bolt too.
If it sounds good... it is good!
Old 19th November 2004, 04:28 PM   #20
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
A word about Greenlee punches from a person who has used and abused more than my fair share:
Its easy to let the die slip causing scratches in the chassis.
They really do work best on thin non ferrous metals. Ive found that using them on steel cover plates for 1900 boxes and larger pull boxes is pushing their limits. Lots of oil on the threads and cutting surfaces is advisable. These plates are roughly 1/8" galvanized steel.
If you can find a deal on the Greenlee die holder, its likely worth the money if your planning more than occasional use. It holds both pieces and has a ratchet handle making it less likely to scratch your work piece.
Ive heard good things about Front Panel Express and have a project that I'm dying to try out with them. I have however found the free layout software a little limiting in its capabilities.
A Bridgeport with CNC is my dream too. It would be nice to have it do engraved lettering too.
How do you punch out your chassis holes? elementx Tubes / Valves 35 14th October 2012 04:52 PM
Chassis/Enclosure that has all the holes on the back precut??? nick_g_evans Chip Amps 3 6th December 2007 06:13 AM
Here is a great tip for you guys building aluminum chassis for your amps russbryant Pass Labs 39 28th November 2004 02:19 AM
Chassis constrution and tapping holes s_c_leach Solid State 7 30th June 2004 11:17 AM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 07:56 PM
Copyright 1999-2017 diyAudio
