What do you guys use to drill holes on chassis??
Old 20th November 2004, 07:49 PM   #41
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by jamesjung21
But does not accept PayPal...
Grainger is a great company, but very expensive -- it's "kindof" your "just in time" high end hardware store for manufacturers... if you break a belt or fry a motor on a packaging system or die caster you can usually get the replacement from them in an hour or so -- they charge premium prices because they stock everything, and they situate their locations where manufacturers o.e.m.'s are going to need them.
Old 20th November 2004, 09:51 PM   #42
rdf is online now rdf  Canada
rdf's Avatar
Originally posted by mjounot
I use Qmax hole punches.... from Princess Auto.
Great tip, thanks!
Old 22nd November 2004, 07:02 AM   #43
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
You might not want to try this, because it can be messy and very noisy, but I've successfully used wood bits to drill holes for octal bases in 1/8" (3mm) thick aluminium.
Old 22nd November 2004, 10:56 AM   #44
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Do you mean a spade bit? Yeah I've used'em for 3/4" holes but after a few holes and my nerves, had to CHUCK the bit! Burned out a variable speed drill doing that! They're ok for quick and dirty holes. And oh yeah if you attempt this method be sure to wear eye protection!
Wayne
Old 25th November 2004, 05:55 AM   #45
ray_moth's Avatar
Yes, I suppose you'd call it a spade bit. Like I said, it's messy and noisy. In my 1/8" aluminium chassis, I drilled ten octal-sized holes, 4 miniature-7-pin-sized holes and three fuse-holder-sized holes using spade bits. I then telephoned my wife, apologized for the noise and begged her to come back home.
Old 25th November 2004, 04:34 PM   #46
Sherman is offline Sherman  United States
Originally posted by DIAR
Someone here recommended this:
Click the image to open in full size. ...
My thanks to that person. The drill works like a charm!
Believe or not but this drill was excellent for drilling 2 mm aluminum...
AND REMEMBER TO USE OIL WHEN DRILLING !!!
I also use a Unibit in my drill press for all sorts of holes in metal, valve sockets, fuse holders, you name it. Works great. I do use emery cloth to remove any burrs and "round" the edge a tad so it isn't so razor like!
I have used that second bit to cut holes in MDF and birch ply for speakers. Take your time, wear a dust mask as well as safety goggles and they work like a charm. Of course speaker holes don't have to be as exact as valve socket holes since the flange usually hides any imperfection. (These days though my plunge router and circle template have mostly replaced that bit so I can do bigger holes and work farther from the edge than allowed by my drill press.)
--Sherman
Old 3rd December 2004, 08:17 AM   #47
Mort Caldwell is offline Mort Caldwell  United States
Use Greenlee punches - there are two punches in their standard set of 8 that exactly fit 7 and 9 pin tube sockets and one that is perfect for octal tube sockets. I've punched hundreds of tube socket holes in aluminum and heavy steel chassis with my Greenlee set since 1965.. I bet you can buy this set of 8 Greenlee punches on eBay for about $25, altho I have not checked that out.
If you are punching a heavy steel chasis, use 30 wt oil on the punch cutting edges and also on the punch threads. Makes the cutting a lot easier, and also will keep your Greenlees going forever!
Another hint is to put the cutter section on the chassis top, to avoid marring it. And use a socket wrench to turn the punch - sure makes it easier..
Happy punching -
Mort Caldwell in West Virginia, USA
Tube circuit building since 1953.. A one tube radio first project
Old 4th December 2004, 04:54 AM   #48
jamesjung21 is offline jamesjung21  New Zealand
jamesjung21's Avatar
I hope so... But no...
The cheapest one I've seen was $55.
I hate my holesaws making soooooo much noise and inaccurate holes...
Old 15th May 2005, 09:21 AM   #49
tazzboy is offline tazzboy  United States
Send a message via ICQ to tazzboy Send a message via MSN to tazzboy
What size hole does the amp input and outputs, eq, bright switch, power and stand-by switches, ground switch, ect have to be?
Plus what are the measurement for the Power Transfomer, Output transformer, Chock, and Reverb?
What do you guys use to drill holes on chassis??Hide this!Advertise here!
How do you punch out your chassis holes? elementx Construction Tips 35 14th October 2012 04:52 PM
Chassis/Enclosure that has all the holes on the back precut??? nick_g_evans Chip Amps 3 6th December 2007 06:13 AM
Here is a great tip for you guys building aluminum chassis for your amps russbryant Pass Labs 39 28th November 2004 02:19 AM
Chassis constrution and tapping holes s_c_leach Solid State 7 30th June 2004 11:17 AM
drilling holes in chassis Raj1 Pass Labs 6 3rd January 2003 07:56 PM
