Power Tubes
Power Tubes
Old 17th November 2004, 01:29 PM   #1
s2kov is offline s2kov  Canada
s2kov's Avatar
Default Power Tubes
What will happen if Power tubes interchange from left to right channel and vice versa? Will it affect the sound and damage the amp?
Old 17th November 2004, 01:33 PM   #2
Mikael Abdellah is offline Mikael Abdellah  Sweden
You mean if you just switch the tube from each channel? Couldn't possibly make a difference as long as the bias point is the same.
Old 17th November 2004, 01:35 PM   #3
s2kov's Avatar
yes, switch both tubes for each channel.
Old 17th November 2004, 08:57 PM   #4
markp is offline markp  United States
Just check the bias and the will be no problems if you switch pairs of tubes.
If it sounds good... it is good!
Old 17th November 2004, 11:16 PM   #5
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Power Tubes
Default Re: Power Tubes
only one way to find out!!!
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th November 2004, 05:21 AM   #6
s2kov's Avatar
Default Re: Re: Power Tubes
eyy! long time no hear.
Old 18th November 2004, 09:23 AM   #7
TonyTecson's Avatar
Power Tubes
yes, right now i am in hokudate, japan for a visa renewal trip, i will go back to russia tommorow, nov 19. my search for svetlana tubes continues!!!
Power TubesHide this!Advertise here!
Power Transconductance Amp with Tubes, How? CLS Tubes / Valves 27 23rd October 2015 09:12 PM
Single-end Power amp with tubes Progg70 Tubes / Valves 3 4th April 2008 02:32 PM
Space between power tubes CarlyBoy Tubes / Valves 7 9th January 2007 03:03 AM
SS No R No C Power Supply for Tubes Audio_idiot Tubes / Valves 1 26th September 2006 08:36 AM
Power tubes for sale airshoo2 Swap Meet 2 9th September 2006 03:20 AM
