drd c3g/300b - help needed
Old 20th December 2004, 08:25 AM   #11
audiousername is offline audiousername  Australia
audiousername's Avatar
Nice Work Love the big oil cap.
Old 31st December 2004, 01:57 PM   #12
garbage is offline garbage  Singapore
garbage's Avatar
hi all
thanks for the kind words regarding the chassis. this is my first attempt at building chassis from scratch (my first attempt at building tube stuff also)
did the other channel... and put in shuguang 300bsc tubes and played for an hour or so.
there is still the slight hum that i hear when i was doing my breadboard... seems it is not due to the drd choke in between the 2 psu chokes... not sure how i can reduce this hum.
the lm338 regulator for the 300b filaments seem to have been busted somehow... all of a sudden my 300b and 83 were glowing.. i rushed to switch off both the supply... not sure why both channels died at the same time. the lm338 is mounted to a large heatsink somemore...
now am using dc but not regulated on the 300b filaments... using them via dropping resistors of 1R each on pins 1 and 4 of the 300b to get abt 5.2v - 5.3v. but one channel only... cos no more 1R. need to get some on monday. can't wait to listen to stereo again.
when there was stereo, the soundstage is slightly forward, bass is tight, vocals sweet, highs with sparkle but not overly bright. driving my totem to levels loud enough for my smallish room.
here's a pic of the amp with the tubes all in, but both side panels opened bcos of troubleshooting.
cheers
garbage
Old 5th January 2005, 12:00 PM   #13
garbage's Avatar
Default a couple more pics
after putting in the 1R resistors for the other channel's 300b filaments
with an intent listener staring at the speakers
night view, lights out
Old 1st February 2005, 06:35 AM   #14
bobhayes is offline bobhayes  Australia
bobhayes's Avatar
Do you still have hum problems?
I see that you have two identical mono blocks, and assuming the hum problem remains in both, from breadboarding to final assembly, I can only think that after trying all your previous remedies, that it might be ground loop induced.
Where is the audio source coming from to your amps?
If your amps are earthed to chassis, and the chassis is the 0v of the circuit, and the source audio device (dac or preamp etc) is also built similarly and earthed, then the RCA leads complete a ground loop circuit which acts like a dirty great bit antenna, picking up all sorts of nasty noise, especially ac hum.
Try connecting an signal lead from the source to the amp but disconnecting the wire screening from ONE of the RCA plugs, or just leave the plug partially out of the socket so as the outer cylinder is not in contact.
Its a long shot mind you.
Old 1st February 2005, 06:42 AM   #15
He still does. There are some posts about it in this thread.
Jason
Old 1st February 2005, 11:33 AM   #16
garbage's Avatar
anything's worth a try...
my chassis is not at 0v of the circuit. seems like i have some problem when doing so.
i just tried to switch the amp on without a signal at one of them. it hums louder.
drd c3g/300b - help neededHide this!Advertise here!
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
help needed from the 300b crowd! Magnetmaz Tubes / Valves 19 3rd March 2003 01:18 PM
Copyright ©1999-2017 diyAudio
