Grounding the Decware Se84sc - diyAudio
Old 15th November 2004, 10:35 PM   #1
icebear is offline icebear  Norway
Default Grounding the Decware Se84sc
Hi
I have been finishinga clone of the decware se84sc but I'm not satisfied with the ground wiring. I also have a small amount of hum in the speakers (audible from my seating. 100dB/W speaker)
Does anyone have a grounding schematics or briefly can describe how it should be done. With tha small amount of components it shoul be easy to explain :-)
The sound is by the way very promesing.
bjørn
Old 16th November 2004, 01:34 PM   #2
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
i guess from the se84sc that the se part means single ended right? with se you get relatively high current draw and none of the hum canceling that pp offers. plus with 100dB/W speakers, this will make it sound louder. you might want to try filtering the power suply a bit more, but this may not offer that much more benifit.
what do you mean by the 'grounding schmatics'??? it should be drawn in on the original schematic where all ground conections should be made. the configuration you use is entirely up to you, but i would recomend star grounding.
Help with Decware SE84 Kit! eeyore Tubes / Valves 1 27th January 2009 05:21 AM
wtb: decware power amp. piwonka Swap Meet 3 28th October 2008 11:10 PM
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Decware OB: is this possible? pjanda1 Full Range 3 29th January 2008 04:51 AM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
Copyright ©1999-2017 diyAudio
