Gary Pimm's battery biased mosfet cccs - diyAudio
Old 14th November 2004, 06:59 AM   #1
sparkle's Avatar
Default Gary Pimm's battery biased mosfet cccs
Hi guys,
I need help form someone that has build the sch. attached or from mr. Gary himself......
I would like to try it on my 12B4 preamp. But since I don't know much about this circuit I have a few questions.
First, mr. Gary uses 3.3V battery cells in the table in his article (from where I have the sch attached). I have 3.6V cells - and because of that I would need to adjust slightly the circuit. Would it be enough to use the same circuit as attached and adjust it with the pot as in the sch or should I change some values.?
Second, he has metioned that he uses 2,3 or 4 cells- I asume that he use them in series with. So if I would decide to use 2 cells I would need 4 battery cells for the whole circuit, right?
Third, and most important of all, what is the voltage drop across the ccs? Is it the same as in other revisions (150V)?
Old 14th November 2004, 07:00 AM   #2
sparkle's Avatar
Here is the table - also from the same article....
BTW, thanks for all Your replies if there would be any.
Old 15th November 2004, 06:07 PM   #3
sparkle's Avatar
is there anybody that could answer my q's?
Old 15th November 2004, 07:05 PM   #4
grataku is offline grataku  United States
GP would probably be able to answer all your questions. Have you tried him?
Old 15th November 2004, 08:08 PM   #5
sparkle's Avatar
Hi grataku,
no I didn't since I know that mr. GP is very, very busy man. I thought that someone on forum might have played around with this type of ccs. So it seemed better to ask those questions here, on forum.....
best regards
daniel
Old 15th November 2004, 08:13 PM   #6
RIP
pedroskova's Avatar
You're more apt to find Gary if you ask over at the tube DIY asylum .
Old 15th November 2004, 08:22 PM   #7
sparkle's Avatar
Pedroskova, thanks - will also try there
regards
is Gary Pimm still around? Nanook Tubes / Valves 9 17th June 2007 09:15 PM
Gary Pimm's MOSFET CCS Fanuc Solid State 4 31st March 2007 10:46 PM
Gary Pimm's site down? Ryssen Tubes / Valves 6 1st March 2007 09:36 PM
Gary Pimm website? SunRa Tubes / Valves 8 29th January 2007 06:06 PM
Gary Pimm Jaime Tubes / Valves 0 24th January 2007 11:03 PM
Copyright 1999-2017 diyAudio
