| diyAudio Sponsor | ||
Which power supply topology for a SRPP? Voltage regulated or current regulated?
Seems like current regulation has some good attributes: great noise rejection, lower total distortion, and higher gain. Bad attributes: the top tube and bottom tube have uneven workloads. Voltage regulation may have good attributes: higher total distortion, but the higher-order distortions are lower. Comments? |
#2 |
Huh?
Power is power... constant voltage preferred. How you get there, I don't care. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
You maybe asking which PS is better , tube or solid state? Well solid state is very good if design is good. I prefer regulated PS with Hexfet as the regulator and zenner diodes as voltage references. Ofcourse ultra fast rectifier diodes , low ERS caps (I use MKP 68uF 600v for best results) must be used. Tubed PS are more expensive and they have much higher inner impedance which can be very tricky. Try somthig like this. It has nice feature , the high anode voltage is not activated until the heater of tube is warmed.
#4 |
Well, I know how to build a voltage regulator or current regulator. I'm looking to understand which type of regulator will be best for a SRPP.
A voltage regulator keeps the voltage stable, but allows current to swing. A current regulator lets the voltage swing, but keeps the current stable. With an SRPP, which variable should be kept stable, the power supply voltage or current? Sch3mat1c thinks voltage should be fixed, and current allowed to swing. Is there a good reason why one or the other should be used? |
#5 | |
diyAudio Senior Member
Be it for an SRPP stage or any other topology for that matter you'd want the plate voltage to be stable as that's how the working points for the valves are defined. Current won't vary much anyway as almost all of these applications will be biased for class A operation so that point is moot. The SRPP in particular likes to see a clean, stiff PS since it has little PSRR of its own. Shunt regulation is reported to sound better than series regulation. Nothing stops you from combining both and take advantage of the intricacies of either one.... Cheers,
Frank |
| HT High Current Voltage Regulator | deltavektor | Solid State | 9 | 17th December 2010 01:23 AM |
| High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 09:43 AM |
| Schematic please? SRPP with current source cathode follower | riotubes | Tubes / Valves | 0 | 7th January 2007 05:18 PM |
| voltage current regulator | ErikdeBest | Tubes / Valves | 0 | 15th June 2006 08:23 PM |
| E182CC, E88CC SRPP at low voltage | yagoolar | Tubes / Valves | 6 | 11th July 2005 11:04 AM |
| Page generated in 0.08576 seconds (72.89% PHP - 27.11% MySQL) with 11 queries |
