Amorphous core transformers only work above 20KHz?
Old 18th November 2004, 01:25 AM   #11
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
How hot? I don't know about amorphous but iron has to be heated to 1500F to change any magnetic properties. (Nickel loses it around 800F. As I recall, gadolinum's curie point is right around room temperature!) Being amorphous, it might crystallize (anneal) if heated above the transition temperature much, after which you have normal steel (again, if it IS steel. I'm too lazy to Google it).
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 18th November 2004, 09:53 AM   #12
edonion is offline edonion  Portugal
I don't know how much hot the core was heated.
I noticed the zone of junction of " C"s had a rectification process.
On that zone, where the rectification millstone was passed, the core presents physical deformations. The stack swelled from 19mm to 21mm.
The dielectric between the lamination disappeared in that zone. They are not agglutinated and they are easy to separate with the finger.
This shows a care lack during that mechanical process and shows there was an exaggerated temperature increase.
regards
Joao
Old 23rd November 2004, 11:30 PM   #13
The company that supplied me C-Cores has already answered my msgs.
They have made new cores which will be tested for the properties I have advised.
They expect to receive them early next week and will dispatch them to me immediately free cost.
As soon as I receive them I will do some tests and announce new results.
regards
Joao
Amorphous core transformers only work above 20KHz?Hide this!Advertise here!
Need Amorphous Core Matching Transformers for Ribbon Drivers NV&H Planars & Exotics 19 16th July 2008 07:53 PM
Plate choke material, why to use amorphous core? noyan Tubes / Valves 5 7th July 2008 12:25 PM
amorphous iron core good or not nhuwar Tubes / Valves 12 28th April 2007 04:00 AM
Amorphous core power trannies for SS amps rick57 Solid State 11 16th April 2006 12:47 AM
Copyright ©1999-2017 diyAudio
