advice for 6L6GC P-P amp - diyAudio
Old 12th November 2004, 02:22 PM   #1
Account Disabled
Question advice for 6L6GC P-P amp
Since Ill rebuild my amp because I have some hum problems (if youd like to see what happened go over here ), Id like to start a new thread to ask some questions to develop the schem.
The bias of 6L6GC is 320V at about 70mA.
1) If you believe that I must change any value of the components for better results, please tell me which one to change.
2) Instead of using 6SN7 as an input tube, do you believe its better to use a single triode driver? I read somewhere that this tube doesnt have internal screening and this may compromise channel separation.
3) Is it better to use bypass cap at the first stage or to leave it as it is?
Old 12th November 2004, 02:24 PM   #2
Account Disabled
And here is the PSU
Old 12th November 2004, 02:58 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Too much C in the PSU, use a choke instead. But that's not going to cause hum unless the current spikes are drawn in via ground loop.
I don't like star grounding. Too damn messy. Just ground the first stage (which should be a 6SL7, you'll have way too little gain as-is) to the input jack, then connect those to the rest of the grounds however you please.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 13th November 2004, 02:09 PM   #4
Account Disabled
Hmmmm....
A 6SL7 or to parallel the two halfs of the 6SN7??
I'll have more gain and not the problem with channel separation.If I'll use 6SL7,one half at L channel and the other at R, I'll have the same problem.
Old 13th November 2004, 02:12 PM   #5
Sch3mat1c's Avatar
Geez, it's going into the same damn room, you WON'T notice 2pF of crosstalk.
You need more gain because you need to remove as much with NFB to get it to sound good.
Tim
Old 13th November 2004, 02:13 PM   #6
Account Disabled
Where is the problem with that?
I prefer not to use chokes!More ringing problems!
Old 13th November 2004, 02:23 PM   #7
Account Disabled
So,there's no any problem to use each half at each channel?
I'm planning to use about 8dB of FB.I think I'm fine with only one half of 6SN7.A Mu of 70 (6SL7) is too much for my purpose.
I think so.That's why I'm asking.Please give me a more clearly explanation.
Old 13th November 2004, 09:20 PM   #8
SY's Avatar
You want more than 8 dB of feedback. At that low level, the THD does decrease, but third and higher actually increase over the open loop condition. 15-20 dB is probably more appropriate.
I don't get the ringing comment. I think the cap situation you show is OK, but a choke at the first pi filter would help efficiency and knock down hum quite nicely.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th November 2004, 06:36 AM   #9
Account Disabled
Since I use PSUDII for my PSU designs I don't like to use chokes.I can't design easilly a stable and not ringing PSU.With caps and Shindo style,things are better.Chokes are more expensive,too.
So, I must change the first tube?
Use 6SL7 as sch3emat1c said or to parallel the two halves of 6SN7?I prefer the last one cause I allready have the tubes and I also can make the two channels identical.
Old 15th November 2004, 11:41 AM   #10
SY's Avatar
With a C-input filter, I don't see any ringing in any of the amps I have on hand. That's not the same as a simulation, granted, but has its virtues. L-input filters will respond nicely to snubbing, but that's not an issue here.
Paralleled 6SN7 will not give you enough gain- you don't increase mu, you just drop rp. Use the 6SL7.
6L6GC AB2 Amp chrish Tubes / Valves 677 Yesterday 06:58 PM
Red Hot 6L6GC oldmanStrat Tubes / Valves 26 29th May 2009 12:53 AM
6l6gc SET, my first DIY alexmoose Tubes / Valves 3 27th April 2006 03:00 AM
Copyright 1999-2017 diyAudio
