Best tweeter amp - diyAudio
Old 9th November 2004, 04:21 PM   #1
nobody special's Avatar
Default Best tweeter amp
I posted this in solid state before, but I would like to hear what the tube people think.
What would be the best amp to use in a tri-amp setup, in your opinion? This would be for tweeters only. Approx. 10-20W power.
Thanks,
Steve
Steve
Old 9th November 2004, 05:36 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
PP 2A3. Are you certain about the power?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th November 2004, 06:49 PM   #3
SY's Avatar
Geez, EC, how about a tube with an actual cathode in it?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th November 2004, 08:00 PM   #4
I would like 10 watts minimum. I enjoy my music loud at times, and I like having sufficient headroom. Thanks for the suggestions, and keep them coming! If you have schematics to pass on, all the better.
Steve
Old 10th November 2004, 12:24 PM   #5
EC8010's Avatar
The reason I asked about output power is that people frequently underrate tweeter amplifiers. Unless you know that the tweeter is more sensitive than the driver it crosses over from, you need exactly the same power. Thus, a typical "Britbox" (8" cone + 1" dome) sometimes has a tweeter that is 3dB more sensitive than the mid/bass, allowing a 40W tweeter amplifier to be used with an 80W mid/bass.
Unless you are using a horn tweeter or one of the new very sensitive ribbons, I suspect you need more power.
SY: Could have been worse - could have suggested 10Y!
Old 11th November 2004, 12:44 PM   #6
The tweeter is rated at 94 db/w. Maybe more power is needed?
Steve
Old 11th November 2004, 08:17 PM   #7
EC8010's Avatar
That would probably be sensitive enough for me. The advantage of a smaller amplifier is that it's a lot easier to build, especially if it's your first valve project.
Old 12th November 2004, 01:24 AM   #8
diyAudio Senior Member
fdegrove's Avatar
Hmmmm........10 to 20W for a dedicated tweeter amplifier?
Really?
I mean, do you really need that many watts to properly drive a 94dB/m tweeter (in a tri-amped system, no less)?
Could anyone be kind enough to shed some light on the theory behind this? And why is PP the recommended way to go, besides the obvious power output advantage, that is?
I mean, if there's any situation where I'd expect a recommend for a SET amp then this would be it......
Frank
Old 12th November 2004, 08:31 AM   #9
EC8010's Avatar
Hello Frank, although a tweeter amplifier doesn't dissipate much power in a tweeter, it needs to be able to swing as many volts at the crossover frequency as the midrange amplifier (assuming equal sensitivity drivers).
And yes, PP because of the power. Otherwise we're into parallel 300B to get the power. A more subtle thought was that the character of a SET would be so different from silicon that it would be difficult to integrate and conceal the crossover.
Old 12th November 2004, 12:46 PM   #10
SY's Avatar
A more cynical thought was that in using it as a tweeter amp, the high HD and output Z would be less crippling than they are for other uses.
Why 2A3 instead of a triode-strapped beam-tube or pentode? Or, for that matter, a 6080?
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 05:09 PM
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 04:41 AM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 07:52 PM
Round radiating tweeter, aka "Enterprise 1" tweeter! tubee Multi-Way 39 13th May 2007 10:03 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 08:21 PM
Copyright 1999-2017 diyAudio
