Should I use a cathode capacitor in my SE amp? - diyAudio
Old 9th November 2004, 08:49 AM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default Should I use a cathode capacitor in my SE amp?
Hi all,
Currently I'm listening to my DIY SE and I am very happy with it. In this amp I'm building an active filter for my new loudspeakersystem, so it's time to strip and rebuild the amp (not as much work as it seems).
In the driver circuit C22 is in the signal path. I was wondering if there are any cons to remove it completely. The interstage's load should be high enough for C22 to be removed, or am I overlooking something?
Ralph
Old 9th November 2004, 09:07 AM   #2
Send a message via AIM to martinab2 Send a message via MSN to martinab2 Send a message via Yahoo to martinab2
C22 is there to bypass R24 so that under AC conditions (music) the cathode of V4 appears to be connected to ground. If you remove it, you will be adding local feedback to the stage.
This might sound better or worse although the gain will be slightly reduced.
Old 9th November 2004, 05:59 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: Should I use a cathode capacitor in my SE amp?
Well, if you are sweating over a capacitor, let me assure you, any logical response on the actual functions of the capacitor are moot.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 9th November 2004, 06:12 PM   #4
Ralph's Avatar
Hi Tim,
May be the best and only answer
Old 10th November 2004, 06:32 AM   #5
Blue is offline Blue  Cayman Islands
Ralph
You have overlooked a few things:
C22 could go but so would all that distortion that makes the amp sound the way it does and nobody likes SE for its neutral sound :-) Is R22 really 62k should it not be 6k (6k2) or is this a magic interstage 1:1 ?? Is there a capacitor somewhere down the line before R23 ? if not there should be; make its value such that the bass rolls off to suit the interstage transformer or preferably the output, my guess is the output is only good for about 40Hz so why push it lower or do you like the TID ? What are R1-R21 and C1-C21 doing ??
Old 10th November 2004, 08:21 AM   #6
Ralph's Avatar
point taken
R22 is really 62K and the interstage is indeed a magic 1:1. I might remove it alltogether.
There are used in my powersupply.
Choosing A Cathode bypass capacitor alexmoose Tubes / Valves 19 7th September 2014 11:08 PM
Question about cathode bypass capacitor: rockgardenlove Tubes / Valves 4 24th October 2008 08:34 AM
What size capacitor I use for a 2A3 or 300B cathode bypass? sgerus Tubes / Valves 20 4th March 2008 02:18 PM
Question about cathode bypass capacitor argo Tubes / Valves 15 20th February 2005 10:26 PM
Does a cathode bypass capacitor reduce hum? ray_moth Tubes / Valves 23 21st August 2004 01:38 AM
Copyright 1999-2017 diyAudio
