Old 5th November 2004, 03:20 AM   #1
Default Good SET for newbie
I built myself a pair of Decwares HDTs loaded with Fostex FE206E (8ohm).
Right now they are running off a simple gainclone, but I sort of feel like I wanna give tube power a shot. I mean these are 97db speakers after all. The caveat is that I'm a fairly poor college student, and I'm not even sure I will like tube sound.
Can anyone suggest an economical tube project? All the decware guys keep telling me that their SE84c (link:http://decware.com/zpage2.htm) is the best I can get for the cash, but they have a vested interest. Besides, $400 for their kit is more than I can spare.
Any suggestions?
-JTC
Old 5th November 2004, 04:08 AM   #2
Brett's Avatar
If you only want a couple of watts, the Gary Kaufman's 6EM7 would be worth trying.
http://www.the-planet.org/6EM7.html
Whatever you decide to build, try to get the best OPT's you can afford, so they're not the limiting factor. They can be obtained for decent prices secondhand and don't lose much value (if any) when resold, or can be recycled into another project.
Old 5th November 2004, 06:37 AM   #3
Stixx is offline Stixx  Germany
Stixx's Avatar
JTC,
I can tell you that the decware amp is an awesome little amp. The decware guys are not beating the drums for nothing.......
Although modest in power it's very revealing and neutral, and can be tweaked some more!
For instance http://joemacjr.home.att.net/diyproject/amp.html# has some good info....
Oliver
Old 5th November 2004, 06:44 AM   #4
audiousername's Avatar
I'd have to second that... the 6EM7 is great! It contains two dissimilar triodes in the same envelope - all required for a two-stage single ended amplifier. Best of all it's affordable (AES was selling them for $2 at one stage) unlike some other overpriced valves which I shall not mention......
The sound quality of many valve designs live or die by the quality of the output transformer. Have a look here http://www.avanwaarde.freeler.nl/id12.htm to see the difference a change from a cheapie Hammond to a Lundahl made to the frequency response of a "Darling" amplifier. It is certainly sound advice from Brett to buy the absolute best you can afford.
The "Darling" amplifier is also a popular (and cheap) single ended project built as a first project. Details can be found here: http://www.geocities.com/TimesSquare/1965/jeremy.html
Also, all of these projects utilise true triodes, rather then the triode-strapped pentodes used in the Zen. This isn't particularly important to me, but may be of consideration for others
Jason
Good Amp Kit 4 Newbie??? Mindcrime Vendor's Bazaar 0 19th April 2007 01:20 AM
Newbie - Is this a good amp? Mas Penk Tubes / Valves 2 11th January 2004 02:17 PM
Good Amp for Newbie PaulHilgeman Solid State 8 4th July 2003 01:41 AM
is this amp good for newbie project?? behnkem Solid State 5 13th March 2003 02:42 AM
Good bookshelf speaker project for newbie dlancep Multi-Way 1 10th January 2002 07:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
