#2 |
I played with some 12E1's about 18 months ago, then moved onto other things. Do you have a schem of your amp? I'm collecting designs for when I get back home (Feb) and get to try some again.
#3 |
diyAudio Moderator Emeritus
That cat isn't sunbathing, she's closely monitoring the current in your output valves! I have a cat who does exactly the same thing. She sits precisely on the centre line between a pair of 13E1 so that she can keep an eye on both DVMs.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
This is the circuit in its current version - probably all wrong but it sounds quite nice anyway. I'm not sure about the driver stage though as most people reckon that a 6SN7 needs lots more volts to sound its best. I got the idea for the amp from peter millett's site where he has done something similar with EL34s. http://www.pmillett.addr.com/el34_active-load_(srpp)_amp.htm I did try the 12E1s with the top one as a pentode but didn't like the sound very much. The srpp driver arrangement makes the sound a bit more punchy and improves the bass compared with the single 6SN7 version |
#5 |
And all that time I never guessed what she was up to !! What does your cat do if the current gets too high?
#6 |
#7 |
Account Disabled
Hi martinab2
Where did you find those pots?I have heard about those kind of pots in the past but I don't know where to find them. |
#8 |
The controls in the picture are vernier knobs that fit on multi-turn pots. I salvaged them from some redundant test equipment from an offshore installation. The rack had been made locally so chances are that the parts were sourced in this country.
I remember seeing these in an RS catalogue a few years ago but I don't know if they still make them |
#9 |
I am not sure whether it's been raised in this forum before but as an interesting contribution to the debate about the appreciation sound your cat reminded me of an observation that the late John Linsley Hood made. In one of his articles, in what was then "Wireless World", he made the point that his cat would leave the room and refuse to listen to certain circuits until they were modified. Anyone else have pets with "golden ears"?
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse. |
#10 | |
RIP
| 12E1 & S11E12 as a KT88 substitution | mobyd | Tubes / Valves | 7 | 26th December 2008 09:51 AM |
| S11E12 / 12E1: best operating point ? | Jaap | Tubes / Valves | 1 | 9th December 2006 02:29 AM |
| Cats That Look Like Hitler | TomWaits | The Lounge | 5 | 27th July 2006 12:55 AM |
| 12e1 sub for 807 ? | exurbia | Tubes / Valves | 10 | 18th February 2005 01:47 AM |
| 12E1 tubes (help) | exurbia | Tubes / Valves | 6 | 20th August 2003 08:23 AM |
